2010 EVO X questions
Ive read the part where the Trans case being overfilled so i will check that first thing in the morning tomorrow. Thing is, i thought the whine is normal for a turbo car. Thought the whine is from the turbo spooling up...this is my first foray in the turbo world. Whine is still faint though so maybe if i let some of the oil out, it will be gone.
Question: is the whine possibly from the T-case or is it just the turbo spooling?
Question: what is the safe boost pressure for the X? i just installed an AEM intake and my boost pressure spiked to 25.4psi according to the accessport live data. the highest ive seen on the stock intake is 23.8psi. Take this into consideration though...ambient temp is 104 degrees, AEM intake, accessport flashed to Stage1 ACN91 + AEM.
So what is a safe boost pressure for the X? if my boost pressure spikes to 25.4psi, will that degrade the block? ive seen 22.5psi before i installed the intake so 22.5psi i thought was the normal boost pressure. but gaining 2.9 psi after the install is a just in my opinion and i just want to know if the engine can handle it. I mean, its just a spike but i dont want to ruin my X in the long run.
is there any way you can detect knock? im not very familiar with the access port,but i'm running a 25 PSI spike on my VIII with no detonation, i am also slightly richer than normal. i would turn the boost down just a hair until you could make sure youre not knocking
Quest
Quest
Quest
Quest
good thing about the accessport is that it is also kind of like a diagnosis tool that can read live data.
about the whining part, is that really the t-case or is it just the turbo spooling?
Ok, so driving today, i saw a peak boost of 26.0psi. Is that normal?
I am using the off-the-shelf maps from cobb accessport website with just an aem intake.
I'm asking coz the highest boost pressure I got from when I was just using a stage 1 tune (bone-stock evo x) was 22.5psi. It didn't spike any higher than that. But now, I'm using a map that is for the use of aem intake.
Can anyone please help answering my questions?
Safe boost pressure level for stock internal?
talek
Mar 16, 2011 07:16 PM
john.schuber
10
Jan 26, 2009 09:38 PM
