Over Boost with bucking after oil change and air filter cleaning.
1 Post
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
This weekend I changed my oil and cleaned my air filter. After this I drove fine until i hit 26-28 psi in fourth and fifth gear normal for my tune is 24.5. I have had my tune for a year and no issues like this until now. I clean my filter every 5k and used the same oil. Any ideas on what my issue could be?
Not sure what would cause that but IIRC, disconnecting your battery for a bit will solve a number of odd problems like the one you mentioned.
1 Post
So, Ive got a new problem, while hard accelerating, I am going lean. So I am thinking that my fuel is running out, fuel pump or dirty injectors? But that still doesn't explain the over boosting. I could use some advice, Ive got the Blue relay installed as well.
1 Post
OK, got some good news, the leaning was fixed by a new fuel pump relay. But I'm still hitting up to 28 psi of boost, no more bucking either. Now I'm debating on if i should get a re-tune.
Sir Kyle (Oct 17, 2018)
FS[SouthEast]: Vibrant 4" Air Filter
hutch959
Sep 27, 2016 05:39 PM
