How to maintain the turbo?
I am new in turbo cars. How to maintain the turbo? How long would the turbo last if I don't drive it aggressively?
Also, how ofen would an EVO and Raillart require an oil change?
Depending on modifications, there may be a little more maintenance required but for now if you are stock/minor bolt-ons, just stick to what is outlined in your manual.
If you do a full track day event you may want to consider changing the oil after to avoid any issues. But as far as the turbo's life goes, that all depends on if you tune for more boost or keep it at stock levels. As increased boost will put more stress on it but I don't see why a stock turbo couldn't go 150,000+km (93,000miles)
You could also get a turbo timer or just idle the car down for 1-5 minutes depending on how hard you've got on the go pedal. I am not sure if turbo technology has progresed (oil/water cooled turbos), but the oil could cook on the bearings without cooling it down. Not sure if you guys are running turbo timers.
Freebs,
I know this is OT, but that is a hell of a fleet you got there in the garage. The Evo must feel like a Civic compared to the Z06.
Freebs,
8OhOh2
11
May 29, 2016 09:58 AM
