I need to know which out of the two is the better buy for a min of 420wtq
http://www.maperformance.com/spec-tw...win-evo-x.html
or
http://www.maperformance.com/exedy-s...ion-evo-x.html
the spec twin, holds more than double the tq that the exedy can but for some reason they are in the same price range. would a better comparison be the spec twin and the exedy triple?
this isnt about saving money, its about which is the better clutch for my goals, which is some where between 420-450wtq(i asked my tuner to keep the tq low because i have a stage 2 exedy).
i need feedback on these clutches from clutch gurus and members who are currently using these clutches.
thanks
Edward
or
thanks
Edward
I don't know about the first one so I may not be much help but I currently have the stage 4Exedy Twin HD and I know It is more than enough for your needs. Once again I'm not sure about the other clutch listed but The Exedy Twin is nice bc if/when you burn through the clutch all you need is a $400 re-build kit and it's back to new. The Exedy Twin can really take some serious abuse as well. The only negative and it depends on the person is the HD is a bit heavy for daily use...I use it daily and it only slightly bothers me in traffic but i'm pretty use to it now. You will need to upgrade your CMC as either of those clutches will break/crack the stock clutch master cylinder after awhile. Hope I helped a bit and if not i'm sure someone else will chime in soon!! I would think either one will do you just fine.
510Finn
52
Apr 26, 2016 12:08 PM
maperformance
EvoX 'For Sale' Engine Internals and Drivetrain
201
Jul 24, 2013 12:38 PM
maperformance
Evo 'For Sale' Engine Internals and Drivetrain
612
Jan 24, 2011 03:01 PM
