BeaterX gets an EF4, thanks MAP!
#48
I added a long runner manifold to this setup so that added some lag but I have a 2.2 now too. So who knows. I liked both so far.
#53
I think people claim it being "laggy" because it's not like the stock. But then again these could very well be people that just started playing in the modded car scene. I know that I am in no way a guru and ask dumb questions, which I have done to Murlo numerous times. But these are also people that probably have never ridden in a big turbo over a stock frame. My HTA3586 is laggy and would never say anything stock frame is as bad.
#54
Ya this is certainly not a stock turbo or ef2/green/BBX Lite, but it is amazingly drivable around town, in traffic, and cruising on the freeway. Pretty much any (realistic) speed in any gear you can stomp the gas and get going, drop a gear if you wanna really scoot, and since my motor is built I've even dropped two gears from time to time (5th to 3rd) so I can nail it at 6500 rpm or so and rev to 8500 for max smile factor
#56
Decided to run a tank of pump gas through this thing. Same tune from shane when the car was on pump gas last year. Timing was just flat with the new turbo from like 5500+ so I added a little bit up there but nothing crazy. It runs good an no knock, just straight MBC, no WGDC at all it is zero'd out across the board. I'm sure it has a ton more in it with a few more psi up top but this is just my 'get me by on pump gas' tune-- nice and safe.
Tons-o-fun!
Kracka
622
May 28, 2020 07:06 AM
scheides
Feb 13, 2011 03:44 PM
scheides
Evo X Dyno Results
10
Aug 27, 2010 07:46 AM
scheides
Aug 23, 2010 08:59 AM
scheides
68
Aug 14, 2010 04:49 PM
