BOV Vacuum hose
BOV Vacuum hose
I have a plumb black BOV. My issue is that the OEM Vacuum line is a 6mm diameter opening, and the one I got with the Turbosmart is only a 3-4mm opening. In the instructions they state that it should be 5mm. Do you think this will make a difference? I don't see how this one can collapse, but do you guys suggest I go get a new line? I would use the stock one however it's way too short!
Thanks
Thanks
I had a similar issue when installing my ets intake. The line that came with the intake was a lot smaller of a diameter than the OEM. I just went to pep boys and got some line with the same diameter as the stock line and cut it to the right length. I wouldn't use a smaller line personally but it won't hurt anything.
evoxbrampton
Apr 29, 2014 05:48 PM
