AEM intake mod
AEM intake mod
The only downside that I've heard of with regard to the AEM intake is that it places the MAF a little too close to the filter, which throws off the reading a bit. The Injen, for example, seems to require a lower MAF compensation, because the MAF is much further away from the filter. But the AEM, with its big box tied in to the OE location for getting fresh air, has the lowest IATs (although the Injen isn't that far behind). My goal is to get the best of both worlds.
The idea is to simply move the MAF a bit further along on the metal pipe, away from the filter. In a dream situation, you'd just turn the pipe around, but the two ends are not the same, so that seems to be out. So, here's the question: how would you move the MAF a bit further back on the pipe?
Mike@RRE said he prefers AEM intakes because they're one of the only ones that DO place the MAF the correct distance away from the filter
Here's one example: http://www.socalevo.net/forum/index.php?topic=83379.0 You have to scroll down a bit, but you'll see it.
If what I've read is wrong, then I'll be delighted. Please use small words if you try to explain it to me. I'm not an engine-guy.
FS[MidWest]: 10.5 Hotside Turbo/Injen Intake/MAF
evopwned
Jul 26, 2016 12:36 PM
