Turbo options PTE BB 6262, 5862, 5858
Wanted to get some opinions on these turbo's from some people that have had experience with them. I've seen several X's with 6262's but not so much the 5862, and the 5858 and I'm just trying to figure out why? Do they just not perform well? I'm going to be running the kit on a stock block for now then eventually build so thats why I'd rather go the kit route then a stock frame turbo setup.
So hopefully some of you can give me some useful info of personal experience with these turbos.
Thanks
Thanks
I'd like to see close to 500WHP with 93 pump on the stock block for now. When I build the enigine I'd like to be in the low 600's on pump. So I'm thinking the 6262 might be the best choise.
NOOOOO!!!! not the 6262.....6266 spools faster and makes around 35hp more than the 6262...plus with a t3 kit with a twin-srool manifold youll spool even faster!!....600whp on pump gas you cant go lower than a 6262!!! if you build your engine with a stroker kit 2.2 or combien with some bore for a 2.4liter with a t3 twin scroll 6266 youre going to have full boost on low 4000rpm and some magical power!!!! .......pt5862 and 5858 will not get you to 600whp!!!
NOMIEZVR4
32
Nov 10, 2012 07:22 AM
