Rear O2 sensor wire question
So I came to notice today that the wire for my o2 sensor is dangling and somehow came unclipped. The sensor itself is still plugged in, but the wire came unclipped and now just drags against the road. The gray wire cover/loom had been destroyed and I could see the wires through.
I electrical taped it up and will attempt to reattach it (i don't have jacks, stands, or access to a lift and my car is lowered)
I have 2 questions...
1. If the wires were messed up so bad, would it throw a CEL?
2. Anyone know what I can attach the wire back to?
Well you have a Cobb AP so it's probably turned the CELs off for that rear sensor. Depending on the wire clipped, if the o2 heater circuit was turned off then the rear sensor is probably damage, but since all the rear o2 measures is the cat efficiency, it's not a big deal.
Already fixed, didn't even have to take it up on a curb! I was able to reach and tuck it under a metal panel, wire is clear of the DP and is tucked firmly away to where it shouldn't come loose. I'll keep an eye on it, thanks for the suggestions!
xPRimNT
157
Dec 26, 2018 08:09 AM
fi8tzer0
Nov 23, 2015 11:15 PM
SCREAM8
Apr 30, 2015 06:03 PM
