Clutch Pedal Issue
Clutch Pedal Issue
Was hoping anyone could shed some light on an annoying issue I've had for about a year. Asked around, but could never get a definite solution.
What I've got: Evo 9 clutch master cylinder. Exedy HyperSingle clutch.
Problem: After the car is shut off for a few hours (even after 2 hours or so), the clutch pedal is pretty much on the floor. After lifting the pedal using my foot, it works fine, and clutch travel, clutch engagement point is fine. No slip, engages just fine.
Any idea of what could be causing it? The system's been bled, and no leaks that I can see. Clutch fluid reservoir never has to be topped up.
Any help / ideas would be much appreciated...
i had this happen on my procharged integra gsr. after letting it sit, the pedal would go to the floor, id lift it up with my toe every morning, start the car and it worked flawlessly. bled it multiple times and never figured out what was wrong with it.
A friend of mine actually suggested that it might be a "slight" leak as well on the master cylinder, between the shaft and the o-ring or whatever seal is there.
I won't even wait 2 seconds, if someone can actually confirm that it's the master cylinder problem.
Lifting it with my toe every morning or after parking, is a bit annoying.
cbarno042
Sep 1, 2016 05:47 AM
cbarno042
Sep 1, 2016 05:46 AM
Dubius
Feb 25, 2008 05:09 PM
