Blue smoke, what to check?
With spring arriving I've been a little heavier on the throttle than usual. A co-worker was behind me on my way to work and saw me take off from a light and observed blue smoke from my exhaust.
Car is stock, but previous owner had bolt-ons and AMS tune.
I checked the exhaust tips and there is some black oily residue on them.
Checked oil fill level and it is a little high (an eighth of an inch above full). Checked air filter and no sign of oil.
Planning to do an oil change tomorrow and making sure I don't overfill this time.
Is there anything else I can visually inspect to determine what the problem might be without taking things apart, or should I take it to the dealer? Car has 27K miles and I am 2nd owner, I believe I'm still under warranty until 5 years after original purchase (which was June 2009).
I suppose I can just do the oil change and see if blue smoke is still present after that before I start to worry. Any advice is appreciated.
BTW I changed the oil after I posted this and the blue smoke appears to be gone. My guess it was caused by being slightly over-filled last time, but I'm not going to sweat it if there are no further issues.
I agree, I believe that the oil being overfilled would cause that smoking issue. Too much oil is as bad as not enough oil. It can cause it to foam up and not protect the internals
onlynamenotused
15
Oct 13, 2018 11:48 AM
Dbzguy
10
Jun 24, 2012 05:20 PM
