Does anyone know if the RALLIART ACD PUMP is the same with evo x ACD pump
The pumps are identical in shape and size from 2008 onward for the Evo X and Ralliart ...the only difference is that the 2 AYC lines are drilled out for the Evo X. To put it another way, you can used the Evo X pump on the Ralliart as long as you plug the AYC ports, but it would be difficult to use the Ralliart pump for the X because you'd need to drill out the AYC ports. You can use the pumps from both if you are rebuilding, and we used a Ralliart pump for parts to rebuild one for the X.
I've been working with a company in England to make the relocation kits for our X's and Ralliarts, 2008+ for our USDM cars...the pumps are different pre 2008. The relocation kits are completed and look awesome making the boot space look stock. I'll be posting pics shortly on the AYC/ACD problem threads if you're interested.
Pics are posted. I'll post one here with the final boot space look.
LookThatsMe
May 11, 2012 06:22 PM
newimportowner
10
Sep 24, 2009 05:57 PM
