FMIC Questions
Old Oct 25, 2013, 07:16 AM
MRak's Avatar
So while we are on the topic, I figure i might as well swap out my UICP while im at it. I have seen that some of them replace/relocate the bypass valve hose. Is there any advantage to this?
Old Oct 25, 2013, 07:21 AM
Kracka's Avatar
Stock location is the best, Mitsu put it that way for a reason. It doesn't look the greatest, but it is functional. I hunted high and low for the best LICP for my car and Depo is what I ended up getting, and now recommend to people. Cobb's is decent too, I just wish it were at least 2.75" rather than 2.5" which is why I didn't go with that one. If you have an intercooler with only a 2.5" outlet though then the Cobb one is fine.
Old Oct 25, 2013, 08:24 AM
T6
T6's Avatar
To put things in perspective, the better air flow you have the better you perform.
Since you already have gotten a slightly used AGP FMIC, grab yourself the depo LICP. Just like mine and you will be very happy when you dyno her. Kracka didn't go with the UICP, i believe it is because either they didnt have the depo UICP or he had a one off piece that is a single piece (that bastard).
Old Oct 25, 2013, 08:54 AM
Kracka's Avatar
My complete intake setup:
-AFE intake w/DryflowS filter
-Cobb 3" turbo inlet tube
-MAP EF2.5 w/3" non-anti-surge housing
-Nisei 1-piece UICP
-MAP prototype FMIC (basically the same as AGP)
-Depo 3" LICP
-Mil.Spec 64mm ported throttle body
-Mil.Spec ported intake manifold
Old Oct 25, 2013, 09:33 AM
MRak's Avatar
so are we saying there is no point in the 3" LICP if you dont have a ported TB?
Old Oct 25, 2013, 11:10 AM
Kracka's Avatar
With the 3" FMIC outlet getting a 3" LICP makes sense, and will be even more beneficial if/when you decided to get the IM/TB ported. If you know for certain you will never ported the throttle body, then it really won't matter much whether you get a 2.5" or 3" LICP; both will work fine.
Old Oct 28, 2013, 12:45 PM
MRak's Avatar
How do you feel about the AGP intercooler piping to go with the AGP FMIC? I dont think the AGP Cold side pipe will work with my MR though...
Old Nov 7, 2013, 07:21 AM
Kracka's Avatar
I'm not a fan of AGP's IC piping to be honest.
Old Nov 7, 2013, 05:02 PM
antyoo's Avatar
Originally Posted by Kracka
Sounds like you could also benefit from the Depo LICP to complete your intake setup! The Depo LICP is a great fit with the AGP since it's 3" in diameter and the AGP outlet is also 3".
oh man, I may just have to buy one...just when I had paid off my credit card
When I got this car, back in August, I told myself I was gonna keep it stock till December. At the rate I'm going it looks like I will be upgrading the turbo in a couple months
Old Nov 7, 2013, 05:44 PM
doom26464's Avatar
Without proper back to back dyno claims like the agp over an ams or ets is better is nothing more then opion. Id like to see dyno or at least mainfold temp back to back for better verfication.
I like ets personally but without any data making statements saying its better then X brand is just an opion.
Old Nov 10, 2013, 08:49 AM
BeyondLimitsEvo's Avatar
Any reason in particular why these pipes don't suit your fancy? I'm looking into a new IC setup as well and the AGP package is quite a bit less than the ETS package, so I may end up going that route.
Old Nov 10, 2013, 06:14 PM
Kracka's Avatar
AGP FMIC + Depo IC pipes is my current recommended combo. I don't like pipe sets that relocate the BOV. Aluminum pipes are also a must for me.
Old Nov 10, 2013, 10:22 PM
Englando's Avatar
Kracka, would the AGP FMIC be better than the ETS 4"?
Old Nov 11, 2013, 05:56 AM
Kracka's Avatar
In my opinion, yes. Cast end-tanks, larger frontal surface area, and a 3" outlet.
Old Nov 11, 2013, 10:57 AM
Englando's Avatar
cool hanks for your advise. Would you use AGPs pipe kit or ditch that and still stick with Depo's pipes?
Quick Reply: FMIC Questions
