Need alil advice
Need alil advice
Ok so i plan on getting the map ef4 turbo for my evoX. currently all i have done is a test pipe, catback and up pipe on the car. Here are parts i plan on buying:
map ef4 turbo
map exhaust manifold
gsc s2 cams
valve springs
ets dp
ets fmic
ets licp
tial qr bov
intake
grimmspeed 3 port
fuel injectors 1100
fuel pump
and a tune..
is there anything i plan on buying that i could hold off buying for awhile and my evo still run good?
map ef4 turbo
gsc s2 cams
valve springs
ets dp
ets fmic
ets licp
tial qr bov
intake
grimmspeed 3 port
fuel injectors 1100
fuel pump
and a tune..
You can skip the licp since the stock one is already aluminum, as for the fmic its up to you if you keep the stock one your engine will heat soak little quicker and you might miss out on 10 HP but that's about it.
Nelson999
35
Jul 25, 2012 03:06 PM
