Prosport Evo Series Oil Pressure Gauge Help
Old Apr 14, 2014 | 05:49 AM
shinku's Avatar
Question Prosport Evo Series Oil Pressure Gauge Help
So I just installed my Prosport Evo Series Oil Pressure Gauge and something is not right here. When I accelerate, the oil pressure stays around 38-43 psi. Same when idling. Not sure if I got a bad sensor or I did something wrong. Pretty sure my car is fine since I just bought it in January.
For those of you who is using the same Prosport Oil Pressure Gauge, do you have a brown, green, and black wire coming out from the Prosport Oil Pressure Sensor? If so, can you tell me where did you connect them to?
Right now, my brown is connected to the fuse box (yellow 20), green is connected to the green wire from the gauge, and black is not connected/not used. I thought the black is ground at first, but when I grounded it, the gauge will just show 0 all the time. Can you tell me what I did wrong here? Any help will be much appreciated! Thanks.
Old Apr 14, 2014 | 06:03 AM
shinku's Avatar
Also, on that instruction sheet It states, ““G” is the signal wire (connect Green wire to “G”). “WK” is a ground. Please run a separate ground to this terminal.” What does “G” and “WK” here mean?
All I have is a brown, green, and black wire coming out from the Prosport Oil Pressure Sensor.
OakosAutomotive
Jan 8, 2020 08:44 AM
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 10:29 PM
mrwickd123
11
Nov 2, 2016 11:19 PM
Epyon
Mar 30, 2016 10:36 AM
OakosAutomotive
Evo 'For Sale' Interior Styling
308
Oct 15, 2015 08:34 AM
Quick Reply: Prosport Evo Series Oil Pressure Gauge Help
