1000cc injectors & 265lph enough for gtx3076r?
I am looking to upgrade my fuel pump and injectors and get retuned. In the future I plan on upgrading to a GTX3076R. Would a Deutschwerks 65c (265lph) fuel pump and 1000cc injectors be enough for that turbo? or would I need a larger pump and injectors?
Those injectors and fuel pump are fine for pump gas. E85 not so much. For a turbo that size on E85 you're going to max out the injectors and fuel pump pretty fast (unless you get a really conservative tune). I would look no smaller then 1450cc's. For the fuel pump a walbro 450 E85 fuel pump should do the trick.
You will have plenty of fuel. We did 476 rwhp 352 tq with a GTX3582 on 93 octane. With FIC 1200cc injectors and a DW 265 pump we were at about 65% injector duty cycle. I would recommend rewiring the pump however.
skyseer
Jan 31, 2012 05:29 PM
