Full Race Kit
Full Race Kit
I know this kit has been discussed a couple of times, but I just want to see if its really logical for my set up. Right now I have full bolt ons, stock turbo e85. I want to do a turbo upgrade, but theres nothing stock frame thatll get me to my goal of 600whp for now (besides gtx3576r but let me explain myself) I would be getting the 8374 turbo, mani, intake, piping, and dp with this kit. This kit would get me way past my goal but obviously I would have it tuned down to around what I want. I am planning on building my motor, most likely a 2.2..will I be okay running this turbo kit with some cams on stock block? is it reasonable? since I am planning on doing a build later I can use the turbo to its full potential when that time comes. this way instead of spending money on one turbo just to sell it and buy another kit I can buy the kit for about $5k all at once and reach my power goal now and then what it will be after my build.
Or put the 5k toward the built motor first and run the stock turbo like Murlo. He seems to be having fun with that setup.
If you put the full race kit on a stock motor, you will still only be able to make 380 torque, so unlikely to be running 600whp.
Murlo also made 600+whp on the ef-4. Since you said, there are no stock options at 600whp. Pretty sure black can get there also.
built motor stock turbo would be really fun to drive all the tq omgggg haha
you can bolt that turbo kit up and make whatever it makes but it is a huggee ticking time bomb if It could last a long time or it could take days to go. It will blow just when will it blow is the question.
SO can you yes!!! will it last probably not.
I say build motor rock it out beat crap out of it stock turbo then upgrade.
Makes most sense.
Also blowing a motor depending on what fails can add plenty of $'s. If you need a new block, you add 2k to the motor built right there.
Good luck I want a built motor too
I'm planning ahead, I'm saving all the money and I'm gonna start buying parts slowly and most likely do it in near the end of summer so I can enjoy the weather with my evo
But then when I build my motor ill be left out of turbo..talked to murlo and he actually made 450 hp and 540 torque which is crazy for the stock turbo. Looks like building a 2.2 is gonna happen before the turbo kit comes.
doyle4281
Jul 3, 2013 05:02 PM
doyle4281
May 12, 2013 07:59 AM
Full-Race.com
76
Nov 18, 2009 03:54 PM
Chris@nolimitmotors
35
Nov 9, 2008 07:57 PM
boosted hybrid
37
Feb 9, 2008 03:57 AM
