Oil leak from turbo?
Recently noticed when I changed my oil there is oil coming out of the turbo where it connects to the upper intercooler pipe. That ain't normal... Car seems to be running fine. However tho about 2 months ago the car did suck up water and hydrolocked (I shut it off asap when I felt it sputter, towed it home cleaned it up and it ran perfectly fine) anyone have any idea what this might be.? Bad turbo.?
Have you done a compression test to see if the cylinders are holding even pressure? I would clean the oil stain and drive. Then check every day or so and see how quick it comes back. And of course check your oil level daily for a while. You did an oil change after the water vacuum right? If not, do. Good luck.
Oil level doesn't go down. I'm thinking tho if oil is seeping out through there I must have a boost leak too. Wondering if that boost leak is somehow pushing or sucking oil out the turbo..? Idk
Its either the turbo pushing a small amount of oil, or your pulling through the crankcase vent hose that goes from the valve cover to the turbo inlet pipe..
As for the oil I havent seen any more oil in these past few days. I do believe though that the gasket that goes between the turbo outlet and the coupler joint is bad. I have also noticed a whistle sound when boosting...? sounds like a supercharger kinda lol I ordered a new gasket and will be posting what i find after i replace it.
Hey, had a shop here remove my turbo when he was removing my downpipe. I had a bad oil return line gasket. Somehow it cracked and since the turbo was never removed it didn't start leaking until the oil return line was taken off. Ordered one from extreme psi for $2.00. Not sure if this is your issue but I would check the gaskets on the oil feed and oil return. My car only has 50k on it so I thought it was odd that the gasket had a crack down the middle of it.
EvoIXMR
Sep 12, 2008 09:02 PM
