Beatrush Rear Differential Spacer - Whine?
Thought I heard the notorious transfer case whine a few weeks ago. Heard the loudest under light acceleration at 5th @ 60mph. Made an appointment with the stealership to see if it could be repaired under warranty.
*Only drivetrain modifications are the Beatrush Rear Differential Spacers and the Torque Solutions Driveshaft Carrier Bushings. Car purchased used, 30k miles in 2014 where all fluids were changed. Current mileage is 43k. Never launched in my ownership. Occasional NLTS*
The dealer tells me that the whine isn't from the transfer case at all; it's coming from the rear differential, but the "aftermarket bushings are stiffer and don't allow the differential to move how it should, thus damaging the differential".
I'm told to revert the bushings back to stock, give it back to the dealer, and they will try to see if the repair can be done under warranty. Oh, side note: it's already been stated they've documented all modifications to the differential. (aka, it's not being covered)
So, I've already eaten a $110 diagnostic fee from the dealership, so they can *@#^ off. I'm more-than-likely to just hand the Evo to either CBRD (1hr) or Moore (2hrs) and have them diagnose what exactly is wrong, and then go from there.
TLDR; Has ANYONE ever heard of the Beatrush Rear Differential Spacers causing any issues within their differential? Or is this a resonating (NVH) whine from the bushings into the cabin? I've never heard of anything whatsoever, especially since Beatrush has them for the VIII, IX and X.
stiffer bushings means transmitted noise / vibration. plain and simple.
your going to hear the rear diff whine and feel it with stiffer than stock bushings anywhere.
as for damage inside the rear diff, i hardly suspect that. like the guy said, revert back to stock and see. im pretty positive the noise will go away if that is the only thing u changed that gave u the noise.
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
... I have absolutely no idea what you're talking about.
Yeah, that's the next step I'll be taking. I'm HOPING that I saved the old bushings when I removed them. I know that the Driveshaft Carrier Bushings were destroyed when replaced, because of dry rotting/seizing of materials, but I'm hopeful that the differential bushings are in tact somewhere in my garage. I'll check this afternoon. If not, that's a $94.06 cost to mitsubishiparts.net. ![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
Stiffer diff bushing means the whine that the rear diff as already making is now audible instead of being absorbed in the squishy stock bushings. Get the diff rebuilt and properly set up (they are generally set up pretty poorly from the factory), deal with the whine, or put the stock bushings back in.
2DCVIN (Jun 16, 2016)
I wouldn't bother swapping back. Your diff started whining the second you installed the bushings. It's pretty obvious that it's just increased NVH. It's something the 8/9 guys are very familiar with, there are many many threads on it..
.. UPDATE: It was NVH from the bushings. Took me 10 minutes to reinstall stock bushings, notice there was no more whine, and put the Beatrush spacers back in. Moral of the story; dealerships are a**holes.
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
![](https://www.evolutionm.net/forums/images/ranks/veteran_air_force.png)
Glad to see someone else had this issue & was able to pinpoint the problem. I have the same whine after installing the Beatrush bushings...I nearly had a heart attack thinking it was a death whine on my 8k mile car. I changed the diff fluid and everything came out clean, no shavings of any sort. I think I'm going to swap back to stock and see if mine goes away too. I sent you an email to confirm I have the right OEM parts list.
Let me know if you're interested in selling the OEM parts you just got.
Same sound
Just bought an 8 and did a short drive no freeway and he told me it had the beatrush bushings and spacers didnt think much of it. Paid him the cash hopped on the freeway and damn is it loud. I know it is better for the drivetrain but its really loud and doesnt sound healthy to me anyways. Has anyone tried anything to remedy this with keeping the bushings? Lube or something idk haha first reply on this site dont beat me up please.
I'm sure you can go on the forums and find someone to swap out with you.
AustEvo
May 4, 2018 03:02 PM
deeman101
16
Dec 2, 2014 09:16 PM
Freebs
34
Jan 8, 2014 05:19 PM
MISHI
Jul 22, 2010 09:44 AM
