Turbo upgrade with stock block
hey guys I know their is plenty of threads regarding turbo upgrades on stock block I would just like to know what would be the best turbo for staying with the stock block and cams? I am 4k above elevation and the reason for not doing cams is their is not any shops I trust to do cam work on my car. Goal would be 450 on e85. Thanks in advance
in my experience the best thing to do is try and find someone with the setup you are looking for and go for a ride. There are alot of other things to consider when choosing a turbo aside from peak HP numbers. The intended purpose of the car as well as the kind of driving you do will also have great bearing on what the correct turbo is to achieve your goals. For the street though i would definitely go for spool / response over peak HP. I think a turbo that would peak out between 450-500 on e85 is probably the biggest you would want for an enjoyable / semi reliable DD.
Thanks the car is used as a DD from time to time but the plan is to have a good street car won't really be doing any racing at the drag strip. I was able to drive a gsr with an MHI and it was amazing how good it pulls, everyone just tells me to go with an EFR turbo. Just don't know if its worth the money without cams and having to replace the downpipe and intake.
Don't have to replace the intake, the CBRD kit works with all intakes.
You can sell your existing DP to recoup the cost of going with an EFR kit. Lots of people do it this way, it's definitely worth it
I will look into that CBRD kit! What made you decide to go with the 7163 instead of the 7670? If I decide to stick stock frame I will definiletly be doing MHI 18k with an exhaust manifold!!
If you can find a CBRD bbx full, those are good options too. I made 500 at the boost creep on one with cams and corn. I was going to go with the mhi, but got a crazy deal on the CBRD.
Also, I just want to clarify, are you looking for 450 corrected, or uncorrected whp? I'm up in denver if you need any local help man!
Nice I've talked to the people at boost creep once before I went full bolt ons and they where booked almost 2 months in advance already! I'm planning on 450 uncorrected DJ numbers I know a few ppl with the MHI 18k stock manifold and cams who've made 410-420 uncorrected . whats shops in Denver would be good to install cams? Thanks for all the help
I've heard mixed reviews of all the big shops like tobz and Carz. Lots of people have good stuff to say about them, and also the negative. Also, MAC autosport.
I had my cams put in by chet when he built my motor.
MAC has the only local DJ dyno that I personally know of, not saying that there isn't others, but 450 uncorrected is close to 560 corrected. That's REALLY pushing it on a mhi, if it could even get there. I'm running 32 psi, and a fair bit of timing of timing on corn to make what I did, and that is as far as I would push my built motor with my particular turbo.
If that's your goal, I'd go with the efr kits.
A gtx35r should do it too, but I've heard that they don't do well at altitude when cams are involved.
Last edited by Mortose; Aug 11, 2016 at 01:42 PM. Reason: Validating personal info. Lol
MAC has the only local DJ dyno that I personally know of, not saying that there isn't others, but 450 uncorrected is close to 560 corrected. That's REALLY pushing it on a mhi, if it could even get there. I'm running 32 psi, and 28* of timing on corn to make what I did, and that is as far as I would push my built motor with my particular turbo.
To be 100% honest, I'll have to get back to you on this. Lol. I'll pull a log and see what I'm reaching up top. You very well could be correct, and I missheard something. I'll report back this evening with my results. Lol
Ive heard the same from all those shops as well which has always lead me to do all my own work. Will talk to Chet and see how much time he has on his hands and might have him do the cam and tune once i decide on a turbo lol Looks like I'm starting to lean towards efr 7670..
Ive heard the same from all those shops as well which has always lead me to do all my own work. Will talk to Chet and see how much time he has on his hands and might have him do the cam and tune once i decide on a turbo lol Looks like I'm starting to lean towards efr *7163.
FIFY.
