Clutch pedal stuck
Clutch pedal stuck
Guessing the CMC took a ****, but anything else you guys suggest looking for? (I looked through past posts and google and everyone is like "CMC is gone").
Looking at Hollywoods how to install a new CMC and it looks "easy" it doesn't look like I have to drop the transmission which has me deceived.
I was also planning to go with MAP's CMC.
Recommendations? (I need to get this car going as soon as possible because it's how I get to work and get my kids to school, but I'm also broke).
OP- I moved this thread to the proper section for better visibility. From the sounds of it as you mentioned it could be the CMC as I know the X's had some issues with those. You can also check your slave cylinder. And of course look for visible fluid leaks and things of that nature. Good luck!
Check the slave, throw out bearing, and clutch fork. I changed my CMC thinking it was the only thing wrong with mine and come to find out my clutch fork had broken in half. Good luck, OP
I have a clutch issue also. Clutch pedal isn't stuck but it won't go into any gears while the car is running. With the car off I can row thru all gears and reverse. Starting the car in gear and clutch pedal depressed, car lurches as if pedal isn't being pushed. What could it be?
LakerRaider
10
Jun 21, 2009 10:59 AM
MuslimEvoFreak
Oct 24, 2005 12:23 PM
