Daytime Running lights
does anyone know how to turn these things off. I am not a fan of DRL. my vette had a single fuse that would disable it. , I will dig thru the manual some more.
ok, Just did it. if you want the walkthru go to the how to section but the down and dirty is grab your manual page 7-42 , go to the fuse box in the engine and pull fuse # 13. last one the bottom row 10 AMP. have fun going stealth.
1 Post
whats strange about these is that i own a 2008 lancer gts. mine didnt come with fuse 13, and some lancers did. My lancer is wired as a "CAN" drive circuit. I recently installed a HID kit, cousing my lights to stay on constant, i really dont think there is a way to disable them yet. Unless you have fuse number 13 and your car wasnt wired in a CAN drive circuit. Even when my car is off it shoots out 12v constant. had me and my installed puzzled...
Just a thought. dunno.
Pulling the light bulb seems the best way to get rid of DRL's. I did it on my Turbo X to get the "light bar" on by itself (see pictures) because in Canada DRL's are mandatory and were always on. Only downside is a message on the information panel "DRL fault left and right bulb". I don't know if the Evo is "smart" enough to detect that the bulb is out. Try it anyways... it takes 2 minutes.
still wouldnt matter if you have the base evo X pullin the fuse wont make the drl go away i believe it only work with SSS evo x that has the stock HID
i never understood the point of drl...they are annoying to me...actually can make it harder to see an oncoming car cuz of the brightness if they are aimed wrong...i mean it just doesn't make sense...cant u see the car fine without them?...as far as foggy or rainy weather...just turn ur lights on...common sense...glad my ix doesn't have drl
