Sponsored by:
Sponsored by: CARiD
EVO X gears
Old Feb 20, 2008 | 06:47 PM
xandi911's Avatar
EVO X gears
someone that has the EVO X can help me please....
someone knows the MAX speed per GEAR of the car...
like how many km/h per gear in the redline..... the manual version with 5 gears...
thanks for any feedback!!
Old Feb 20, 2008 | 08:29 PM
Stangar's Avatar
Here's the speed (MPH) in each gear at 7000 RPM
I'll let you convert it to KM/H.
7000RPM - 38.6mph 56.5mph 76.6mph 100.6mph 144.9mph
Old Feb 21, 2008 | 01:58 AM
hiphopp's Avatar
basically, at 7000rpm, the top speed is 144.9mph?
Old Feb 21, 2008 | 02:49 AM
trexxx8739's Avatar
you can just hit 60 mph in 2nd gear. Thats how its quicker than the STI
Old Feb 21, 2008 | 05:57 AM
Evil_X's Avatar
From Road & Track magzine.
Gear/Ratio/Overall/(Rpm) Mph
1st,:1 2.86/13.41/(7500) 43
2nd,:1 1.95/9.15/(7500) 63
3rd,:1 1.44/6.75/(7500) 85
4th,:1 1.10/5.16/(7500) 112
5th,:1 0.76/3.56/est (7500) 162*
*Gear limited
http://www.roadandtrack.com/assets/d...Vwrx_chart.pdf
Old Feb 21, 2008 | 11:35 AM
xandi911's Avatar
so the redline is 7000 rpm OR 7500 rpm!?
someone wrote after you 7500 rpm...
im talking about MAX REVS pear gear....
thankss
Old Feb 21, 2008 | 11:59 AM
Evil_X's Avatar
thankss
7000 looks to be the redline from what the tach shows. Not sure where the rev limiter kicks in at though.
Old Feb 21, 2008 | 12:27 PM
Stangar's Avatar
Yes. That is correct for a 5 speed manual 2008 Lancer Evolution GSR.
Old Feb 21, 2008 | 02:46 PM
Evo_Jay's Avatar
The tach shows redline at 7000RPM but fuel cut is 7500 or 7600RPM
Old Feb 21, 2008 | 03:53 PM
xandi911's Avatar
since the fuelcut is 7500 it worth the max revs posible...
so i will use all the 7500 RPMS right!?
someone can confirm?? thanksss
Old Feb 21, 2008 | 06:02 PM
mrdevo's Avatar
The power drop off will determine when you shift. Those mph are at 7500rpms, far past the intended use or redline.
Old Feb 21, 2008 | 06:04 PM
gotevo?'s Avatar
confirmed.. mine hits fuel cut @ 7500RPMs... and the speeds listed above are correct... at least through 4th gear... haven't run 5th all the way yet... yet lol
Old Feb 21, 2008 | 06:27 PM
Evo_Jay's Avatar
No the power from the stock turbo falls off. Its best to shift around 7000-7200PM on the stock turbo.
Old Feb 22, 2008 | 08:09 AM
stunt1o1's Avatar
the gears R shorter than the VIII
Old Feb 22, 2008 | 06:05 PM
big block ix's Avatar
7200 bummer
Quick Reply: EVO X gears
