Turbo Cool Down for Evo X
are there any guidelines for turbo cool down with the evo x? the manual is very nonspecific and there is no turbo gauge to tell how hard you are boosting. i am still breaking my engine in so boost has been minimal but i have no idea how much i boost in normal driving.
any thoughts are appreciated.
I typically let it cool down for 20-30 seconds after regular driving (<4k). Often if I'm about to arrive somewhere I make sure I go real easy on it and dont go thru hardly any RPMs. That way I dont have to let it cool longer. If you're doing some quick spirited driving I usually leave the car on for a few minutes or so once I'm parked. So far so good.
When i had my 05 Srt-4 after normal driving on the street or highway I would let it cool down for 3 min. But if i drove the car hard(turbo housing glowing orange) I gave it a 10 min cool down with the hood up. Call me crazy but i never had a problem.
^ its not the coolant you are worring about its boiling the oil that is left in the turbo if you turn the car off and the pump stops. you want to keep circulating it through to cool it off. i normally let it sit for 30 sec after normal driving and if i do canyon runs then a few minutes.
True I was a lil paranoid but I read an article a few years ago on proper turbo cool down times and depending on the oil used and oil change intervals, hot oil could coat the ball bearing in the turbo over time shortening the lifesapnd of your turbocharger. A turbo timer takes care of these kind of worries though
porsche is the same way. they dont mention a cool down really either.
Quoted from Wikipedia:
A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off
I have a lead foot and I love the sound a turbo makes and you leave your opponet in the dust. So when i buy my X I probably will be but a Turbo Timer
Man, it's just like 2003 all over again.... No cool down is necessary if you drive properly: just keep your foot out of it for the last part of your journey (if you live in a subdivision this shouldn't be a problem).
No, the car has a built in feature that will activate based on certain conditions. If those conditions are met then some fans will run and whatnot to cool it down for 3 minutes after the car is truned off. No turbo timer is needed and no cool down period is needed for regular usage.
