Can't lock doors w/ turbo timer
Turbo timers are pretty overrated. Unless your car is built up and/or you've been hardcore tracking or beating on it you shouldn't really need to be letting the car sit there idling for more than like 10-15 seconds...MAX!!
Most people who use them probably think it will befuddle other non-car people to see a car running without a key and shut itself off and that adds to their enjoyment. Otherwise it seems a bit silly to have one, especially if you are running into problems.
As you near your destination stay out of the boost for a few minutes and your car should be completely fine to shut off if it worries you so bad. If that's not good enough, let it sit there for a little. It doesn't have to sit THAT long. If you are ragging on your car up until you get to your destination you should probably change your driving habit.
now besides the fact i ran into a prob, it sucks. and i drive my car like an evo that it is and waiting anytime at all is wasting time.
i just would like to be cautions and not have to worry either way... theres a fix and its somewhere, its just a matter of time finding it.
last time i checked it wasnt a problem to be cautious...
I have somewhat of the same problem with my IX.
It has a viper alarm and HKS Type 0 and when i try to arm the alarm when the TT is on, it wont arm, but i can use the factory keyless FOB to lock the door.
Maybe because i didn't connect the ECU wire from the TT?
On another note - i don't just use the TT to let the car cool down, i also have it warm up my car. I run outside, turn on the car, set for 3 mins, run inside and do some other stuff. Quite handy if you ask me.
well tomorrow i plan on taking it out to do a test... i cant remember if the car would lock if the car was still running like say i had to run to an atm and didnt want to shut the car off but leave it running and lock the doors behind me.
now if that works and it does lock then we know that its a TT problem and should be an easy fix. now if it dont lock then its a mitsu thing and its gonna be a headache trying to get that fixed.
and since it is installed and a headache, i have it set to 30 seconds and usually i can see my car from where im going or i will wait till the timer is in the single digits and lock as im walking away...
does anyone know if having the navi installed, would u be able to adjust and turn on and off features like this threw the navi?
i know this thread has been dead a for a long time...
checking to see if anyone has figured out or have solved the problem.
my buddy has a apexi timer and his does the same thing.
now has anyone experienced hard driving on there X and when u shut the car off with no timer does the car actually shut off or remaining running till it feels the car is cool enough? cuz if it dont then that oil is just sitting in there wether or not the fan is on or off.
just still looking for some insight.
thanks
thanks
on my last 2 cars I had the same problem. What I noticed was that I could manually lock the doors but when the car shut off they would unlock again. I had to find out the hard way as someone went in my car and stole my stuff. The best solution is to remove the turbo timer as you don't really need it on an X.
my previous car (mazdaspeed protege) had the same problem.
i had to mess with the wiring in the ignition and basically hardwire the turbo timer AFTER the alarm.
IGNITION ------ ALARM ----- TurboTimer
the factory alarm had to be tricked into thinking that the car shut off as soon as you took the key out.
the way u guys have it hooked up now is: IGNITION ----- TurboTimer ------ ALARM
Hi people, I installed my Blitz timer two weeks ago. I never get a chance to test the lock door thing.
Today, I finally test it. It works !! I walked more than 2 ft. away from the car while T-timer count-down. After the car shutoff, you will see the interior turns off, then the door will lock at the same time. The whole thing takes about 1 min from the time you turn the igition to off.
Unfortunately, the headlight has to be switched off manually when you get out of the car. I don't think it matters.
