Can't lock doors w/ turbo timer
#46
But even with that said, that means that it should be something that can be changed in the ecu. I don't know much about tuning or accessing the ecu but is there a way you can look at all the paremeters on the ecu so we might be able to find this issue?
#48
Like I said before, this is controlled by the computer and it can be changed its just a matter of time.............................................. ..........................
#56
If you hear a whirring noise after you cut off your engine, that's an electric fan cooling water that's sitting still in the radiator.
If you don't want a turbo timer, that's up to you. If I want one, that's up to me.
#57
im thinking really the only way to do it is this, roll window all the way down, lock doors hit auto up and walk away. Which in turn though is really a huge pain in the rear and makes running a turbo time painful!
#58
I would think that if the car needed a turbo timer for heavy daily street driving, then Mitsubishi would have installed one.
If I've been driving the car heavily, I'll let it sit for 30 seconds or so before I shut it off. But otherwise, I seriously doubt I even need to be wasting the 30 seconds. It's probably all in my damn head because of all the people that have turbo timers. Either way, I read the manual cover to cover, and I never read anything about letting the car idle after driving heavily, to avoid turbo damage.
#59
This is the reason Mitsu should release a damn PDF of their owner's manuals, so we can easily search for crap like this.
