Fog Light Switch
Old Jun 13, 2008, 05:13 AM
gotrnet's Avatar
Fog Light Switch
anyone know how to bypass/change the wiring so that you can turn the fog lights on when ever you want and not just when the lights are on. is there a relay i can bypass? so you could have your day time running lights on and the fog lamps? thanks.
Old Jun 13, 2008, 06:44 AM
JaxRRevoX's Avatar
bump
Old Jun 13, 2008, 07:23 AM
StevenStarke's Avatar
its not that easy
Old Jun 13, 2008, 07:48 AM
BoricuaEVOX's Avatar
i had this done on my old eclipse, but i had an auto shop do it.
Old Jun 13, 2008, 07:49 AM
mitsuboost30's Avatar
not that easy on the evos you have to make a circut boardto bypass electronics... i was thinkin about producing em.. but just dont have time
Old Jun 13, 2008, 07:52 AM
GeorgiaBoy's Avatar
I would like to see that mod also. Bump for a how to
Old Jun 13, 2008, 02:16 PM
Red Dragon's Avatar
you can always cut the factory wires and rewire everything.
Old Jun 13, 2008, 02:45 PM
EvoXstylin's Avatar
I was wondering about this too.
Old Jun 17, 2008, 07:01 PM
gotrnet's Avatar
just wanted to thank everyone. i figured out how to put it on a switch and keep full stock functionality.
Old Jun 17, 2008, 08:41 PM
Jblade's Avatar
^Do you mind writing that up for us in the DIY section?
Old Jun 17, 2008, 09:02 PM
dac001's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=248060
Old Jun 18, 2008, 03:56 AM
GeorgiaBoy's Avatar
^^That mod is for the 8,9 evos anyone have anything for the X yet?
Old Jun 18, 2008, 06:46 AM
gotrnet's Avatar
here is a link to a pdf showing the wiring diagram for the foglights.
http://webpages.charter.net/gotrnet/...glight_mod.pdf
i put a note on the pdf as to where to hook in. it is on C-312 plug on wire 4 and is blue and black. it this plug is located on the bottom of the fusebox that is behind the flap near the drivers door. you have to access this plug from the floor board area not this flap but that is the box. i took a few pictures but i don't have them with me at work. i will see what i can do about putting them up later. this is all on the ground side so all you have to do is hook into this wire and run it to a switch and then run a wire from the switch to a grounding point. if you cut this wire and wire in a switch then you will ONLY be able to turn on the fog lights with that switch. if you piggyback this wire then they will work as usual with the foglight switch on the steering column (when the low beam lights are on) or when ever you flip the switch that you wire in. one note of caution, the foglight will come on ANY time switch is on, meaning when the car is off so it could be easy to kill your battery unless you wire in a relay that only allows it to work when the car is on. enjoy.
Old Jun 18, 2008, 01:20 PM
gotrnet's Avatar
updated it with photos to help. enjoy
Old Jun 30, 2008, 05:33 PM
EvoDan2004's Avatar
bump for an easyer way. seems like a project not everyone can do. crap i dont even know what im looking at. can we just get a switch and wire it in to go on and off whenever we want. granted the factory switch wont work but its the only way i can think of without being part of nasa to make this circuit board
Quick Reply: Fog Light Switch
