Blow Through - Vent to Atmosphere
#46
They're actually very similar to each other except the Q flows more air, so they sound a little different. The Q actually uses the exact same springs as the 50mm, but they're rated differently for each valve since the internal height is different.
I just got the old 50mm because I found a used one in perfect condition for cheap, otherwise I'd probably have the Q.
#51
i'm still not 100% sure of the benefits of this set up. the turbo spools faster and u can run a bigger intake pipe and a vta bov?
is that it or can u explain why this set up is beneficial and worth the money? i'm just confused and want some explanation, not trying to criticize at all.
#52
as stated in the very first post, the only benefit for me was ease of switching between my autox setup and my street setup. i unfortunately was the victim of some parts that were not properly advertised as incompatible. so instead of going back to the stock setup and trying to sell my buschur lower intercooler piping i tried to find a way to make it work. this thread is the result. there are very few real benefits, you can adjust the air readings of the maf some by twisting the maf around but it is much easier to just get a tune. i only have this up here for those people that like that vta sound, which is purely cosmetic in my opinion. once i found out it worked i thought i would share with the rest of the community. there maybe other advantages, but this was my reasoning behind doing this.
gaulrich2003
For Sale - Part Outs
13
Nov 26, 2009 10:25 AM
-Evo Aaron-
Oct 9, 2009 12:31 PM
03volkevo8
23
Sep 2, 2009 11:03 PM
