Headlights uneven
#34
The fact I can adjust the beam hight from inside the car in the MR-T is so cool, I'm not used to such luxury, see my other cars in sig.
#36
Defininitely a good thread. I too, was going to have a talk with the dealer...thanks for helping in averting an unecessary scene!
My driver side headlight appears to be a hair lower than the right, and as an MR-T, it has internal adjustments but that just shifts both, keeping that left one a hair off...so I can just tweak it with a philips and am good to go?
#37
(First post)
Good to know that the driver-side light is suppose to be lower than the passenger-side.
I think I'll muck with the adjustment screws some to see if I can get rid of some of the pronounced chromatic aberrations (non-white areas of light) around the cut-off.
#38
Yeah, my 2010 RA sportback got same prob as u have "The left side beam seems a little closer compare to the right" ... and even worse, mine is almost 5 ft. closer compare to right side. They are " HID low-beams" only prob I believe, since my high-beams are just fine...
PS: just saw the answear... good to know it's supposed to be like that lol
#39
Does anybody know how to adjust the non-HID headlights??
My lights are pointing down way to far, so my field of view at night w/the low-beams is next to nothing. I've read every single headlight thread here, and at the 'other' forum, and most describe the somewhat similar method for adjusting for HIDs.. but the gear mechanism seems a little different between the two.
Anway, I've found the correct opening for the screwdriver and found the gear with the bolt at the end (bolt head is flat) as shown in the pics and diagram. Are the teeth of the philips head supposed to make contact with the teeth of the gear to turn it? If so, does turning the gear require much effort and should it make a "click" sound or anything?? Also, it looks like there's a black plastic piece underneath the gear teeth that appears to have a small raised dot that comes up between 2 of the teeth -- should I be using the screwdriver to bend that part down, so the gear can turn.
I've also read a recommendation of using a 5.5mm socket for the bolt, but on the non-HID lights, that socket is just way too small for the bolt. Also saw mention of a plastic cover that's supposed to protect something, but haven't found anything similar.
Thanks in advance if anybody has any info.. just didn't wanna break anything!
#40
Glad I found this thread. I think mine are aimed improperly. Even on 0 setting, they're way too low and to make matters worse, the passenger side is aimed way wide and is lower than the drivers side. Signs don't light up LOL. I'm going to aim them super high and then just dial them down a few notches inside the car. Very informative thread. Sigh, I wish mitsu would have cutoffs like the s2k's.
#41
THANK YOU... for this post. My drivers side headlight was aimed DANGEROUSLY low, to the point where if there was something in the road ahead of me on a dark night, I would barely have enough time to avoid it once it came into my field of view. Other than our coke-can sized fuel tank, this was my only other complaint about this car (especially after my dealer told me there was no way to adjust the headlights). One step closer to perfection after this easy fix.
#43
The diagram posted by Q15H is correct. It took me a few times to get this right. The right tools help too. I used an eight inch number 2 Philips screwdriver. It is a little bit of a tight fit. It has to be twisted into the hole to start turning the plastic gears. Turn left to raise the lights. It's slow to raise so be patient.
#45
I've been wondering why my passenger HID seemed so much higher! Even with the dashboard height setting on max they are both still a little low for me. I will give the assembly a tweak and see if I can raise both sides a bit.
