Need more Fastest Stock Turbo Evo X on the list!
I was thinking it's kind of silly that there aren't more Evo X's listed in the following thread:
https://www.evolutionm.net/forums/sh...d.php?t=317423
I mean XtremeBoost & I are soakin up all the glory!
If you ran your Evo X with a Stock Turbo at the drag strip, be sure to send in your times to get on the list assuming you felt it was a good run of your car. No need to stir up a hornet's nest of Evo X bashers with any 17 sec timeslips!
Keith
My plan for this Wednesday at the strip is to preload the Forge actuator some more and see if I can force the turbo to hold more boost past 6k RPM. Failing that I'm going to try some 100 Unleaded and lean it out slightly with a slight voltage change to the MAP Sensor which I've already tested to be working as expected based on my O2 voltages. I'm also going to try no lift shifting at around 7000-7200 since I just lose boost the higher up I shift and the turbo is already pegged at 38 Lb/min flow. I'll try launching at lower boost off the 2 step and 25-30 psi tire pressures so that 1st gear isn't a tire melting affair.
If none of that improves my times then the Stock Turbo is finshed! I refuse to pull more weight out of the car beyond the spare, tools, and sub for racing.
Nice times, although that is a modified stock appearing turbo and this particular list is for 100% stock turbos with no upgraded wheels. Currently there is a lynch mob going after an Evo 9 owner (Manny) that others are saying was running a Green Turbo, just a heads up! haha
You would definitely fit on this list for Fastest Evo X's though:
https://www.evolutionm.net/forums/sh...d.php?t=344544
boomn29
Jul 8, 2019 05:09 PM
APM Racing
Midwest Region
149
Jan 13, 2014 11:31 AM
ETS Michael
EvoX 'For Sale' External Engine / Power
16
May 19, 2013 06:00 PM
COBB Tuning
58
Jun 17, 2011 11:28 AM
COBB Tuning
31
Feb 26, 2011 03:48 PM
