jack failed....dented floor
Old Sep 27, 2008, 08:41 AM
EvoM Community Team
atombomb33's Avatar
Originally Posted by aiden1983
I think what he was saying is that he jacked up the car then was going to slide in the jackstand from the front and the jack failed. I have had a hydraulic jack do this to me before, but didn't have the jackstand under it. Ya just use a block of wood and a hammer.
+1...that's exactly what it sounds like. And, sometimes s#!t happens. Rubber mallet will do the trick. Anyone else saying that this guy doesn't know what he's doing, hasn't played around in their garage long enough to know that a hydraulic jack can/will let go at times. That's why you should never be under the car with just a hydraulic jack...you need the jack stand which won't fail.
Old Sep 27, 2008, 08:47 AM
flyboytb's Avatar
+1000000
my hydrolic failed with my 5500lbs truck over me luckaly there was clearance for me to not get pinned.
Old Sep 27, 2008, 08:52 AM
fox2boost's Avatar
use a four by four and a big hammer
Old Sep 27, 2008, 09:04 AM
aiden1983's Avatar
Ya I use wood to block my car and a jackstand before I get under, better safe than sorry. Honestly it will only take you 2 min extra and you know that you will be safe. Glad he is ok. A dent in the floor is minor in the grand scheme of things.
Old Sep 27, 2008, 09:33 AM
tsitalon1's Avatar
Thats why I built my own ramps! But in this case, it wouldn't of helped because you can't rotate tires on ramps
Old Sep 27, 2008, 09:36 AM
Mightygnu's Avatar
I don't see why you couldn't take the extra 3 seconds and put it in the right spot, but use a rubber hammer!
Old Sep 27, 2008, 11:11 AM
toro10's Avatar
this is only tangentially related, but since we are on the topic of getting under the cars or lifting them up(in this case) - what ramps are you guys using. Will an X clear Rhino ramps?
Old Sep 27, 2008, 11:24 AM
JoeyM3's Avatar
hope you get it fixed, shouldnt be too bad.
Old Sep 27, 2008, 03:34 PM
flyboytb's Avatar
nope.
Old Sep 27, 2008, 04:28 PM
Joe's Evo X's Avatar
Old Sep 27, 2008, 06:30 PM
evo 8 shyne's Avatar
Originally Posted by white_turbo
Good thing that you were under the car.....the rubber mallet is the only way you can pop that thing back down.
Old Sep 27, 2008, 07:00 PM
jebus27's Avatar
Doesnt the dealer offer free balance and rotation???
Old Sep 27, 2008, 07:06 PM
white_turbo's Avatar
Opps....I meant "were not"
Old Sep 27, 2008, 07:12 PM
tath133's Avatar
Check the undercoating for cracks/damage and touch up.
Old Sep 27, 2008, 10:50 PM
zasboy's Avatar
A rubber mallet should level out the bump.
Quick Reply: jack failed....dented floor
