Nisei Uicp New Aluminum Version W/ T-bolt Clamps Installed!
whats the difference among the brands offering the uicp? why should i pay 240 for a nisei rather then 300 for a ams uicp besides the price? i'm very picky when it comes to my mods but i also want the the best performance at a reasonable cost.
I will say this though: price is a good indication of quality but the most expensive doesn't always equal the best. Unless there's a massive difference in price, it really comes down to which company you feel makes the better quality product. Much like beauty, quality is in the eye of the beholder. Anyway, if you would like to learn more about what goes into making these pipes and what to look for when buying one from whoever you buy yours from, here is a link from the Nisei forum explaining the differences between a 1 piece, mandrel bent design like theirs, a two piece (which they also offer), and two piece multi sectional welded pipes like AMS'.
http://nisei-evo.com/forum/viewtopic.php?t=616. Scroll down to the 3rd post and it explains everything. Good luck with your purchase.
Yep, the couplers allow for enough engine movement to be perfectly safe. The unit still utilizes the core support with the rubber gromets also, so there's a bit of flexibility there as well. The car that was used for prototyping this unit was tested on the track with no issues whatsoever. It's a very well designed product. I can't say enough good things about it. Nisei FTW!
^Ahh, it aint that bad! I actually just wiped all the dust off of the plastics and hoses with a wet paper towel after the install but not before the pics were taken. I don't know why I didn't just take the pics after the cleanup but hey, I was tired and it was time for a and a test drive, but not in that order .
I ordered the 2 piece aluminum pipes yesterday. Hopefully will get it next friday. Cant beat the price on the 2 piece design, and should and fit equally as nice. Cant wait to install mine.
Agreed. You just can't beat the quality and aesthetics of nisei products. Did your kit come with the T-BOLT clamps? I know the early versions didn't, although it really doesn't matter because worm clamps are fine enough but I will say this; these T-Bolts are no joke! They have such wide, fat contact points on the hose and just torque tighter than the wormies do.
I can't stress enough though that when tightening these, use a socket wrench that has a multi ratchet function where the handle twists like a screw driver in addition to the normal movement. Not only do these types of socket wrenches make quick work of tightening or loosening loose bolts, but you can feel the level of tightness with your wrist muscles, which helps prevent overtightening the clamps because when you use your arm with the normal ratchet movement it's really easy to overtorque things because of the leverage increase.
I can't seem to find a better way to explain what I'm trying to say so I hope that makes sense.
We've actually just got a couple of these 1pc UIP's Matte Black in stock as of Friday 10/31!
Also, got 2 pcs Matte Black Aluminum Type A and B in stock for less. Starting at $170.
Type A
Type B
Type A
Type B
The problem with my unit is I am still battling a leak near one of the couplers. The coupler I received seems too short or the piping is just off a tad.
I also found the type B with the coupler and clamp on, it scratches the oem connection right under it. Which is why most company only makes type A or one piece style.
