View Poll Results: Have you had issues with fuel starvation at the track?
Yes
41
33.61%
No
20
16.39%
Haven't been to the track yet, so not sure...
61
50.00%
Voters: 122. You may not vote on this poll
Ams Fuel Surge Tank
Old Jan 5, 2009, 09:41 AM
  #46
MrBonus's Avatar
Originally Posted by 4GSix3T
I don't disagree with you (I see it all the time) and I don't beleive I was making it seem like it was epidemic, I did not mean to come across that way. I was speaking from personal experience and it happened on street tires with a half tank. I would just hate to see something bad happen from fuel starvation. I could have been more specefic with what I was refering to. I can see it being a much larger issue for the hardcore track guys.
Oh, totally. I didn't mean to come off as crass. Your point is very valid.
Originally Posted by UFO
I don't think you're lucky; your track probably doesn't have any high speed left hand sweepers. It really does only seem to be the higher speed left handers that cause the problem as I've had no problem with the slower corners.
As for the surge tank solution: I can't see myself running this in my daily driver....
Well, the Evo is no longer a daily driver.
Yes, thinking back, the tracks I've run on do not have any long, high speed left handed sweepers. Maybe that's why I've been lucky.
Old Jan 5, 2009, 10:06 PM
  #47
smgevo's Avatar
great pic! Looks like it will fit with all the factory pieces in place. Don't plan on DOT approval though Great solution for those experiencing problems.
Old Jan 6, 2009, 05:58 AM
  #48
MrBonus's Avatar
So does the surge tank essentially eliminate the rear seats?
Old Jan 6, 2009, 12:43 PM
  #49
BlackTrack's Avatar
No, it sits behind them in the trunk. AMS and I both ran full interiors at Super Lap with the Surge Tank kits installed.
Old Jan 6, 2009, 02:14 PM
  #50
smgevo's Avatar
Have they sourced the proper vapor sealed gas lines yet? Is there any risk for street driving of the tank leaking or exploding in an accident? Great product and I want one!
Old Apr 23, 2009, 08:48 PM
  #51
joowick's Avatar
any news on this?
Old Apr 24, 2009, 01:58 PM
  #52
Hiboost's Avatar
I'm interested as well since I would rather just upgrade my fuel pump once with this setup than mess around with in tank adapters for the Evo X. Watkins Glen seems to be mostly lower speed left handers and is a right handed course but I don't want to push my luck. The only times I've noticed my TurboXS knocklight flicker slightly was exiting the turn 10 off camber left hander. It's more than a 90 degree turn and it has me thinking that the fuel was losing pressure in the rail and about to cut out. Please tell me you guys are close to releasing an official kit for the Evo X!
Old Apr 25, 2009, 04:08 PM
  #53
flyguycfi's Avatar
Man I can't wait to see this kit!
Is there a bypass for the surge tank if you are just daily driving or is a full-time system?
Old May 5, 2009, 04:59 PM
  #54
Hiboost's Avatar
Lightbulb Some ideas
I'm pretty sure this would be active all the time since you couldn't pressurize the fuel rail with just the factory pump feeding through the surge tank, the pressure would bleed back into the gas tank via the overflow line.
Ok some brainstorming here:
I know the "Walbro 255 LPH HP" fuel pumps are rather noisy, what are other alternatives even if they are double the cost but quieter? Maybe two "Walbro 255 LPH OEM" fuel pumps? Looks like 2 of the regular pumps would do 50-60 GPH at 70 PSI (~40 psi fuel pressure plus 30 PSI boost). May be trouble for higher boost levels though.
http://www.lightningmotorsports.com/walbro.htm
Also another thought was most are only getting fuel starvation on left turns where the fuel sloshes to the passenger side. I haven't looked at how the stock fuel pump pickup is setup but couldn't you center it more to balance the starvation and hopefully hold it off a little longer?
Lastly, much fuel is being returned through the return line when at part throttle, would it be enough to fill a small in tank reservoir that had one way valves of some sort that would let fuel in easily but restrict the flow outwards? You could mount the pickup inside that assuming there was some sort of way to anchor it down. Just some ideas...
Here is what the STi cars have:
http://tuspeed.com/store5/fuel-anti-...ank-p-644.html
Old Jul 13, 2009, 07:09 PM
  #55
808_EVO's Avatar
Any updates on this?
I've been checking the AMS site periodically but haven't seen it out yet...
Old Aug 17, 2009, 08:37 AM
  #56
chuwey25's Avatar
Hi, was just wondering if anyone had any more info on when this will be available as it resolves exactly the problem I have been experiencing on my track days - i've not seen any updates on AMS's website yet tho!
Old Aug 17, 2009, 12:41 PM
  #57
Hiboost's Avatar
Last I heard this was put on hold due to the assembly having to be inside the cabin between the trunk and back seats raising safety concerns. I'll let AMS confirm as perhaps I misread it, Ill see what I can dig up.
If they do scrap it then possibly taking another angle at this would be to come out with a larger capacity fuel tank that incorporated the reduction in fuel starvation in the fuel pump assembly design. Even though I managed over 350 miles and over 29 MPG to the shootout this year, having an extra 3-5 gallon capacity would extend range to 450-500 miles if you kept speeds around 70 mph.
Extending the fuel tank 1-2 inches lower would require you to also modify the fuel pump assembly to stay lower in the tank to accomodate that change and pickup the fuel at lower levels. From some basic research it seems that anyone could get a tank custom made to those specs but the question would be cost. Integrating a swirl pot around the fuel pickup area with the new tank would make this worth the money if it were to cost in the $800-$1200 range in my book.
Old Aug 18, 2009, 01:28 PM
  #58
chuwey25's Avatar
Hi, thanks for the reply, I will have to wait to here from AMS - unless you hear anything further in the meantime!
Old Aug 18, 2009, 02:01 PM
  #59
Tractionlimit's Avatar
I wanted to do this since I'm doing heavy fuel system work for E85 anyway. Last I checked, AMS is not recommending this for use in a street driven vehical and there are some liability concerns. I decided instead to try an in-tank Walbro HP and a suplemental in-line Walbro HP. AMS will be tuning it next week. This won't address the starvation issue, but I have yet to see that with the stock pump and FPRed autocrossing and on the slower tracks I run. I'll be watching this one close though to make sure the higher fuel flow doesn't compound the issue.
razorlab
Dec 6, 2016 08:45 PM
ryukinevo
Nov 13, 2015 12:00 AM
krisiun
18
Nov 23, 2013 10:13 PM
krisiun
North Texas Evo Club (NTEC)
28
Dec 11, 2010 08:53 PM
KevinD
Dec 9, 2010 08:16 AM
Quick Reply: Ams Fuel Surge Tank
