What would i need to get 350WHP?
Old Dec 1, 2008, 03:13 PM
TrueX's Avatar
what would be the cheapest way to get the GSR in 11's? with bolt ons and tune?
Old Dec 1, 2008, 03:32 PM
EvoDom's Avatar
you do not need a bigger turbo to run 350 awhp.
-intercooler, full piping, turbo back exhaust, intake, boost controller, manifold, and a fuel pump with a good tune will put you up close to your goal. i would say 330-340 awhp.
throw some cams and re -tune and boom over 350. stock turbo is ok for 350
worse comes to worse throw some meth in.
Old Dec 1, 2008, 04:07 PM
zTargeTz's Avatar
Turbo back, boost controler and Zchip (plus 93 octane as long as your not at crazy high alt.) should get you in the 340-360WHP range
and cheaply
Hell, a test pipe, boost contoler, zchip at least 91 octane and a dry 50 shot of Juice will put you in the 350-375 WHP range (say good bye to your stock clutch)
Old Dec 1, 2008, 04:46 PM
EvoG8r's Avatar
If you want 11s, you'll need full bolt-ons, a tune, plus a better clutch... or a small turbo upgrade like the artisan sa-50 (or whatever its called).
Old Dec 1, 2008, 04:57 PM
evoWWrs's Avatar
350 you will need........... intake, turboback exhaust, Manual boost controller, bigger FMIC with upper and lower ic pipes, walboro, and bigger injectors!!! you will be right at 350whp after good tune... if it is possible for you, switching to e85 will get you near 400.... if you want to upgrade turbos, get a FP red, which is a stock turbo with ligher wheel, ect you will be BEYOND 400
Old Dec 1, 2008, 05:00 PM
evojanoy's Avatar
Injen intake system
Greddy Turbo back
Forge BOV
Greddy Boost Controller Profect II.
ECU Tek Tune
Exedy Twin Disc
Old Dec 1, 2008, 05:01 PM
evojanoy's Avatar
I got a 1.9 60 foot so with a better launch it would be in the 11.8's
Old Dec 1, 2008, 05:45 PM
TrueX's Avatar
Nice!! that is what i am looking for!
Old Dec 1, 2008, 08:54 PM
evoWWrs's Avatar
tune tune tune!!!!!!!! seriously tho, e85 is amazing, if you can get it DO IT
Old Dec 1, 2008, 09:27 PM
xtremeboost's Avatar
some good parts and boost
Old Dec 1, 2008, 10:10 PM
TTP Engineering's Avatar
The zchip has consistantly added 60-107whp to the Evo X.
www.zchip.net for more info.
Old Dec 2, 2008, 11:07 AM
TrueX's Avatar
How much does it usually cost for a good clutch and installation?
Old Dec 2, 2008, 01:51 PM
ExcessLancer's Avatar
hmmm i want the z chip.lolo
Old Dec 2, 2008, 04:50 PM
hel_if_ino's Avatar
Take a look at my sig... I am 8 hp shy, a fuel pump would put you over the top probably. Not much is required on the X to make those numbers.
Old Dec 2, 2008, 06:47 PM
About $1,200 or so .
Quick Reply: What would i need to get 350WHP?
