Battery disconnect before intake install?
4. Reassemble Vehicle
a) Position the inlet pipes for best fittment. Be sure that the pipes or any other components do not contact any part of
the vehicle. Tighten the rubber mount, all bolts and hose clamps.
b) Check for proper hood clearance. Readjust pipes if necessary and re-tighten them.
c) Inspect the engine bay for any loose tools and check that all fasteners that were moved or removed are properly
tight.
d) Reconnect the negative battery cable to the terminal.
e) Start engine. Let car idle for 3 minutes. Perform a final inspection before driving vehicle.
This is from the AEM CAI install directions. So not hearsay.
Oh and here is the link. Page 12.
http://www.aempower.com/images/produ...s%2021-678.pdf
tight.
dsmbruno
11
Apr 16, 2008 07:22 PM
hotrod2448
Dec 14, 2005 01:48 PM
nalevy
10
Feb 27, 2004 10:20 AM
