Broken hood latch! :(
It has something to do with the cable rusting inside the sleve. Mitsubishi sent letters to all thoose that they felt had effected cables. But if yours is having that same problem see your dealer and they will replace for free
yeah I called the stealership...set up an app. for tomorrow... hopefully I get it fixed will post comments after I come back from the stealership
it's good to know that im not the only one with this problem ... should have a recall ASAP!
yeah, if you are having a tough time opening the hood, bring it to the dealership and as long as you are under basic factory warranty, they will get the issue fixed for you. There is a TSB on them issued earlier this year or late last year.
PURPOSE
On some vehicles equipped with turbocharged engines, corrosion on the inside of the hood lock release
cable can make it difficult to release the hood locking latch using the latch handle. This Service Campaign
authorizes dealers to replace the hood lock release cable with an improved part designed to prevent internal
corrosion. Refer to the Parts Information section of this campaign bulletin for additional information.
AFFECTED VEHICLE(S)
2008 Lancer Evolution built prior to October 15, 2008
2009 Lancer RALLIART built prior to October 15, 2008
NOTE: Dealers are requested to inspect their new and used vehicle inventories and repair affected
vehicles as described in this bulletin
This is directly off the Mitsu Dealerlink site
PURPOSE
AFFECTED VEHICLE(S)
i checked my car but what i did to improve this problem was that i moved the rubbers which align the hood when its closed i moved them lower this seemed to help a lot also i used grease on the mecanism and know all is fined.
if you would have rust build up on your cable then the lever would be dificult to pull even when the hood is opened ,mine was very loosed up when the hood was opened up.
also to is300 do you feel anything better with the new cable?and you should check with them why didnt the new cable bring the rubber plastic.
good news...took the car to the stealership and they told me they would fix the problem under warranty..and that was aware of this...sad part was that they had to order the cable so won't get the beast back till Thursday..will post result when I get her back....ahhh miss her already
Saves the hassle...
