Removing trunk carpet to access top strut bolts
OK, I feel a little silly asking this, but I'm just stuck.
I'm trying to track down a clunking in my rear suspension. Everything is tight on the bottom of the car, so I'm now going to check the bolts on the top of the strut. I know that I need to remove the trunk carpeting to access the top of the strut, but I just can't figure out how to get it all out.
I made quite a bit of progress, but how do you remove the plastic "pins"? (they attach the black plastic pieces, which need to be removed because some of the carpet's edge is behind the black plastic) Do you just pry them out from the side, from the middle, ? I don't want to break or scratch them.
TIA,
--michael
TIA,
--michael
TIA,
--michael
TIA,
--michael
There are two types of clips. The ones at the back of the car near the trunk opening just spin off. They have a little handle to help this.
The ones holding the plastic to the bracing on the back of the trunk (behind the seats) are the typical plastic pop rivets.
They look kinda like this:
You put a flathead screwdriver under the lip of the center section and pry the center section out. Then the entire "rivet" comes out. There are 4-6 of them holding the center plastic shroud on. Once those come out and the plastic comes out the carpet just falls out.
Thanks everyone (especially goofygrin for the pictures), I got it figured out. I just didn't know how to get those plastic pop rivets out, but a flathead screwdriver to pry them out easily did the trick.
Also, for anyone doing this, make sure to remove the trunk lid weatherstripping rubber. It's easy to remove (and replace), and sure makes getting the carpet panels out easier.
Now if I could just figure out where my clunking is coming from... even the top strut bolts were tight...
No, it's bone stock.
No shipping blocks in the springs either.
I have another thread for my clunking sound: https://www.evolutionm.net/forums/evo-x-general/437147-clunking-sound-passenger-side-rear.html
if your car is purchased from a mitsu dealership and there is a warranty on the car, i would just take it to them. let them deal with it and this way it will be documented.
EGbeater
28
Jul 18, 2019 01:24 PM
RallySport Direct
Evo X How Tos / Installations
21
Jul 16, 2014 07:07 PM
DarksideEng
57
Jan 13, 2014 09:33 AM
VADER X
22
Oct 5, 2012 09:41 AM
Kracka
22
May 11, 2010 07:37 AM
