Tips for a first time beginner at the track - Driving Evo X MR
Hey fellow Evo owners. Tomorrow I will be heading to Buttonwillow, California to attend the Performance Driving Clinic. This will be my first time setting foot on a real track and I was wondering if you guys have any good advice for a beginner. I will be driving my 2008 Evolution X MR so there are a few gadgets I'm confused about setting up.
For example, do I set my transmission in Normal, Sport, Super-Sport, with or without manual controls? I also have a Blitz Throttle Controller, should I set this to SP1, SP2, SP3? Do you guys recommend that I also turn off traction control?
I also understand there will be a lot of following so why set my transmission to redline every time on Super Sport mode and SP3 when there a car in front of me? Any other general advice would be appreciated. Thanks!
I hope the temperature there isn`t too hot, otherwise you may encounter the Slow Down warning if the SST temperature gets too hot after 15mins or so. I would definitely look into the SST oil cooler upgrade before hitting the track.
To answer your question, I would set the SST to S-Sport and let the transmission do the shifting for you. Blitz TC would help a lot too, SP2 and SP3 is designed for track use.
Temperature will be ranging from 80s to mid 90s but there will be 50% clouds. Hopefully I don't get the alert to "slow down" Any advice on traction control settings? Would an open face helmet work better or close face helmet?
make sure you have motul dot 4 brake fluid in your lines. Bleed your brakes. If you are still on old oil, i would do an oil and filter change before heading out. If you are concerned with brakes, I would at least get something better than oem pads especially in that heat. Get a CG-Lock to hold you in better. Bring tools, jack, jack stands just in case. Now go have some fun and stay safe.
P.S. If you happen to put 2 wheels off, make sure you drive STRAIGHT OFF, especially the last esses and the turn before the main straight. There are walls on the inside, so don't try to be hero and save it after the fact or else you will go straight into them.
jeezes it pains me to read some of these posts, put it in super sport mode/automatic and drive it like a rental car in bagdad at night. if it over heats, limp back and let it cool off. then do it again. car is under warranty beat the ever living sheeet out of it. of course make sure it has oil and I put the tires at 40 psi stiiffens the sidewall. if you dont put it on the grass once you are taking it to easy. My MR was in normal mode once. never again if I wanted a camry I would have bought one.
I don't have any advice specific to the X (I have an 8), but I did like the following advice:
Take out your entire bank account in $100 bills. Tape them to the dash to remind you how much money you have. Drive accordingly.
I'm going to VIR next week. I plan on having a lot of fun, going fast enough to scare myself again, and driving home with the car in one piece.
Being the fastest car at a track day or HPDE isn't worth much. Enjoying yourself and learning about your car and high performance driving is the best fun you can have with your clothes on.
You're not insured on the track. You'll have a great time no matter how you do and you're going there to learn.
