Attention All X Owners.... Do this ASAP....
#136
Just ran into this problem today. I had a zip-tie on one end (stupid me didn't zip tie both ends).
However, I found that even with two zip ties on the intake manifold end, the hose is still relatively easy to pull off by hand. I wasn't happy with this, so I went searching for a hose clamp. 3/8" was too big, so I looked further and found this 35 piece Dorman kit at Autozone:
http://www.autozone.com/autozone/acc...mString=search
This kit includes what they call "fuel injection hose clamps". These are the correct size for this application. However, even with this hose clamp on, I could still pull it off relatively easily by hand. Finally, I took off the hose, used some hairspray on a paper towel to coat the metal tube, then put the hose on with the mini hose clamp. I now can tug at the hose with a bit of pressure without the hose moving. I'll report back if I have problems, but I hope this solution stays (hairspray + mini hose clamp).
#137
There's no lip on the metal tube, so even friction clamps like zip ties and hose clamps can still be pulled off.
That said... you put an extremely flammable liquid on part of your engine?
#138
I figured that people use hairspray on intercooler hoses and it's fine...but now you got me paranoid. I just put a bit to help it stick. Is hairspray really that flammable after it dried into sticky residue?
#139
super glue is the trick
#140
This happened to me a few days ago so I zip tied it and it corrected my idle but it's still not 100%. I do have some aftermarket parts on (intercooler, exhaust, intake) with a stock tune on it. Would the idle be corrected from a tune or is there something else I should look at like the fuel pump relay? I also get fuel cut/overboosting or whatever it is during close to or at WOT described perfectly in this thread Hesitation/vibration/jerking/kicking/overboost, high rpm, ASC off & Service Required on evoxfouurm.com (wouldn't allow me to copy paste the url)
#142
I brought my car to the dealer 3 times because of shaky idle. It started after having service done for my AC. I am glad to know this is a common thing that happens on its own, because i started to assume the service tech did it to me in revenge of my complaint to corporate... heh still dont put it past them to do something like that, but couldn't believe I saw the hose hanging there after they were unable to find the cause. How does a service tech miss that 3 times?
#144
#146
You'll be fine. It didn't happen to me until I was tuned to 25lbs. I just zip tied it and it hasn't happened again. Congrats on the new car!
#148
1 Post
Was driving along and all of a sudden heard what appeared to be a IC Pipe popping off. Nope... Couldn't figure it out. Idle was super rough and couldn't boost past 20psi. This was like last week. Just jumped on the forum, found this thread, and went to check. Sure enough my hose was popped off. Test drove and car is back to normal Thanks for the info!!!!
#149
Just happened to me. I knew about this issue so when I got to school yesterday I took a look but I guess I over looked the hose seeing how it is pretty tiny but, when I went out today I saw that it had popped off. Thank god, I was getting worried it might have been something worse.
