Attention All X Owners.... Do this ASAP....
#211
Happened to me and I noticed it after looking for a long time for a vacuum leak. The car will idle so bad. I used a old hose clamp and looks great now. Why they didn't clamp it? Weird
#214
(I'm not taking credit for this picture....)
There is a hose from the Fuel Pressure regulator to the intake manifold. Mitsu did not put any type of clamp on this hose. It will pop off and cause you to run lean, and ruin your idle. It is a simple vacuum line, but is difficult to see when trying to diagnose a problem...
The hose is located near the dip stick. All you need is a couple zip ties....
Heres a pic.
There are one 2 many "My idle is shaky" thread on the opening page..... this is likely everyones problem....
Heres a pic.
#221
Sub'd. X has been idling similar to this. Checked under the hood and the part of the hose going to the intake manifold seems to be attached and zip tied (THANKS previous owner). Going to pull the cover off tomorrow and make sure the other end is attached and zip tied good when I change out the tranny fluid.
