Attention All X Owners.... Do this ASAP....
Old Jul 24, 2014, 01:57 PM
  #271
Iowa999's Avatar
Originally Posted by mrFabro
Cable Zip tie can handle up to 185, average engine temp is 150?
Excellent question.
Nylon zip-ties can handle much more than 185*F, which is good, since our engines run a lot warmer than 150*F.
Old Jul 26, 2014, 07:19 AM
  #272
Quebedo28's Avatar
Thanks
Old Aug 1, 2014, 05:29 PM
  #273
Samdiver1974's Avatar
Just did this today on my 2014 MR manufactured date was Aug 2013
Outside diameter of the hose in question is 8mm as measured by calipers.
I have mine zip tied at the moment but waiting to get 6mm and 8mm Corbin clamps and see which one fits and works best.
So assuming that the hose comes from the fuel pressure regulator to the intake manifold, that fuel mists through the hose, this could be a fire hazard if the hose is off.
Old Aug 3, 2014, 08:27 PM
  #274
LB_Reddy's Avatar
Thanks.gotta check mine ..if it pops off its gonna run lean.
Old Aug 7, 2014, 07:44 PM
  #275
MrDarkman430's Avatar
This is actually very helpful considering i'm having an issue with my AFR right now. And come to think of it my idle is shaky sometimes. I will definitely look into this...
Old Aug 8, 2014, 02:57 PM
  #276
Boston.George89's Avatar
awesome thanks for the picture it makes it easier.
Old Aug 8, 2014, 04:59 PM
  #277
Ruthless671's Avatar
My 2010 Evo X with 32k idle was fluctuating and threw a P0171. Cleaned the MAF and checked all hoses and everything was secure. I was getting frustrated until I saw this tread. Thank you for saving me anymore heart ache. It was really hard to miss if you weren't looking for it specific, but that vacuum hose was surely disconnected. Threw on a tie strap, cleared the code, test drove and she is running perfect once more.
Old Aug 9, 2014, 04:29 PM
  #278
bigguss69's Avatar
I had that same problem..little zip tie will handle that
Old Aug 15, 2014, 04:23 AM
  #279
Suarez11mx's Avatar
Already done
Saw this post last night , checked first thing in the morning , it was already zip tied thanks everyone
Old Aug 21, 2014, 03:30 AM
  #280
n00bis's Avatar
Saviour... Bought an 2009 Evo X today and was driving it home when I realised it was having idling issues. Searched around the net... Found this thread... checked the car... All fixed!
Old Aug 26, 2014, 10:05 AM
  #281
gkswhdl88's Avatar
Thanks for the post!
Just zip tied mine.
Old Aug 27, 2014, 10:12 PM
  #282
Overlook's Avatar
Good info, gotta let my buddy at work know about this.
Old Aug 28, 2014, 06:02 AM
  #283
nvmaddog's Avatar
Took a look at this the other day and gave it a nice tug, thing didn't budge a millimeter.
I'll keep watching it, I'd like to see if over time it will loosen up.
Old Sep 1, 2014, 01:05 PM
  #284
EmanantEvo's Avatar
Took a look at this hose on my '14 GSR. The hose was connected and did not seem to be easily moved. I installed a 5/16" spring wire hose clamp (picked up from my local ACE Hardware) as a short term solution to help prevent the hose from coming off. The engine bay is full of spring action hose clamps, so I imagine there is one from Mitsubishi that could be used for this application also. Since the fitting the hose attaches to is not flared, it would appear that the hose will eventually come off (once it dry rots) with or without a clamp. Does anyone know what kind of pressures are seen through this hose and in what situation are they seen?
TxFAkuma
Aug 9, 2015 08:01 PM
j1
Mar 30, 2015 12:39 PM
blknblubkrdude
Jul 21, 2014 12:23 PM
evodriver49
May 16, 2013 12:04 PM
MISHI
13
May 8, 2011 11:04 PM
Quick Reply: Attention All X Owners.... Do this ASAP....
