Evo X gas pedal stem broken off, very dangerous (merge)
Old Sep 13, 2009, 05:50 PM
  #391
svt04cobra's Avatar
Dam scary!!!!!!
Old Sep 13, 2009, 05:57 PM
  #392
ODUB's Avatar
how is that scary? there's no way a case like that would hold up in court because honestly, what's the danger of the gas pedal breaking? if it breaks, the car slows down. wow, so dangerous. the only thing that would be dangerous is if the brake pedal broke, or even if the clutch pedal broke in gear. the gas pedal breaking is annoying sure, but not dangerous.
Old Sep 13, 2009, 06:37 PM
  #393
flyguycfi's Avatar
Originally Posted by odub
how is that scary? There's no way a case like that would hold up in court because honestly, what's the danger of the gas pedal breaking? If it breaks, the car slows down. Wow, so dangerous. The only thing that would be dangerous is if the brake pedal broke, or even if the clutch pedal broke in gear. The gas pedal breaking is annoying sure, but not dangerous.
+1
Old Sep 13, 2009, 08:21 PM
  #394
ugakirk's Avatar
Isn't this the second one? This freakin sucks!!!!
Old Sep 13, 2009, 08:28 PM
  #395
mpboost's Avatar
I'm not worried about my gas pedal. Only two people have actually reported this problem.
Old Sep 13, 2009, 08:31 PM
  #396
Toxin's Avatar
You're waiting to turn into a street, you start turning your gas pedal breaks... An SUV that you went before is heading directly in your side...
Not dangerous at all. As long as the brake is working.
Old Sep 14, 2009, 07:16 AM
  #397
svt04cobra's Avatar
Can you say assclown??? How is the gas pedal breaking not scary? Maybe in the OP the situation was not scary but what happens if you pull out into traffic to make a u-turn and the pedal breaks with on-coming traffic coming, or you pull out to make a turn, you have plenty of time but traffic is coming and the pedal breaks? I stop at my friendly neighborhood coffee shop every day of the week and when I come out of the plaza I always have to pull out with on coming traffic to merge in. Not scary is an understatement.
Old Sep 14, 2009, 07:22 AM
  #398
tweakdsm's Avatar
I think more than 2 people..... but 2 people is enough, show me previous evos with broken gas pedal. This should be a recall, peroid. how about if broken pedal goes under your brakes.? o.O
Old Sep 14, 2009, 07:27 AM
  #399
gizmotoy's Avatar
Something should be done on this. Definitely scary. It'll only get worse as these things age and the repeated stress gets to them.
Old Sep 14, 2009, 08:14 AM
  #400
06MR6's Avatar
Not scary...
I'd ALMOST assume that you put a TON of pressure on your pedal under WOT, which will cause a lot of stress on a pedal... Maybe not all the time, but enough to break a pedal
Your wife driving it? Probably not putting 50-100lbs of pressure on the pedal at WOT frequently.
And DON'T try to claim that you RARELY go WOT...
Old Sep 14, 2009, 08:18 AM
  #401
06MR6's Avatar
Now it would make sense for Mitsubishi to put a strong pedal in a car every owner will put through the paces.
Old Sep 14, 2009, 09:19 AM
  #402
Xtremist's Avatar
Yes it's scary and could lead to injury or death but the only thing that's a positive here is the fact it's a drive by wire throttle system and not the conventional gas pedals found in older vehicles! Once the pedal brakes; the car slows, at least where not getting a sudden surge of gas!
P.S. Until the OP posts pics, don't believe everything you read/hear I know how people are, they constantly try to blow issues up on the internet over one instance, I'm not calling him a a liar but I know how people are, nothing against the OP once again I'd just feel better seeing different pics of another issue in where the pedal broke.
Old Sep 14, 2009, 09:24 AM
  #403
JonBoy's Avatar
Sure. Since it's completely unreasonable that you might be pulling out into traffic from a stop, going through an intersection (from a stop), or on a road with no place to pull over and with traffic potentially coming up behind you. All of those could happen and you'd have no way to get out of the way properly or pull over safely.
Old Sep 14, 2009, 09:25 AM
  #404
cheb evo's Avatar
You are calling him a liar if you say you don't believe him without pics. There have been other stories of people having their pedal break on them, so I believe this can happen.
Agree that it is very dangerous given that you are merging into traffic or trying to pass someone with a car coming in the opposite direction. Glad the OP is OK in this instance.
Old Sep 14, 2009, 09:40 AM
  #405
gizmotoy's Avatar
Originally Posted by 06MR6
Not scary...
It doesn't take a whole lot of pressure to cause a stress crack in incorrectly braced plastic. As was mentioned in previous threads, the bracing Mitsubishi used is inferior for the direction of force in this application. Compare our pedals to Porsche's plastic pedals to get a feel for how it should have been done. I'm surprised that design made it through quality control.
Maybe he puts a lot of pressure on it, or maybe the plastic had a defect that led to its failure... either way a pedal should not fail. Using proper bracing, adding a floor bumper to prevent excess travel, or using a floor-mounted pedal like most other DBW cars would have prevented these incidents.
Quick Reply: Evo X gas pedal stem broken off, very dangerous (merge)
