How to stop boost taper?
Here is Perrin's definition. It's a good write up.
http://perrinperformance.com/pages/show/113
there's no adjustment on your mbc, where as the ebc, u can add gain up top at redline. Another good thing about ebc is that u can set boost for any gear u in. Example: 30psi 1st gear, 30psi second gear , etc. Your mbc can only give u full boost on 3rd and 4th gear. If u want more than 30psi, u gotta have an ebc. period. Just ask every shop tuner, they will tell u.
Yes, a 3 port with the factory boost control is the best option possible right now.
Any EBC will not work as well and not only that will not keep the failsafes from the factory.
You don't need an EBC to run 30psi+ i don't know why you say that...I have seen plenty of other cars with a simple mbc run 38psi from spool up to redline...has nothing to do with power.
the ebc do come with an port solenoid too, isnt it the same as the 3port solenoid? Well Murlo, the shop i went to tune and race anything from 240sx, evos to 1500whp supra, most of them car use greddy profec ebc. They dont recommend mbc. Who know man, they might be wrong. Both of my evos got fix and tune there.
A MBC and EBC accomplish the same thing, the EBC just has a solenoid valve controlled by the controller (man that sounds dumb, lol). The only nice thing about an EBC is that it gives you setpoints to do quick switches and some allow boost by gear as you said.
A MBC is just one PSI all the time, it will build to that PSI as fast/slow as the turbo allows it and hold that PSI as long as possible and holding boost is purely based on your wastegate and turbo abilities.
It's really a waste to talk about this, the factory boost control with a 3 port is the best option as it eliminates the factory bleed type system and retains all the boost control of factory tuning allowing you all sorts of craziness and safety measures.
