Sponsored by:
Sponsored by: CARiD
Buschur Racing's major EVOX build
Old Jan 15, 2010 | 05:02 PM
  #31
KPerez's Avatar
Black OEM Relay: Source of Failures?
Dave, it is noteworthy that #4 cyl on UR car had a damaged plug and resulting loss in compression. This is exactly what has happened to others as TTP has diagnosed (see https://www.evolutionm.net/forums/ev...misfiring.html) and it has been suggested also that the relay may be the underlying cause. U have suggested same. Now it appears from UR above posts that this OEM black relay is still in the car. Could U please grab this relay and replace with the headlight green replay and see if lights function. If it fails then it would appear that the cause for these engine failures is, in fact, due to the relay. If not, then the relay is not the culprite. Thanks for UR help on resolving this issue.
Later, Ken
Old Jan 16, 2010 | 06:20 AM
  #32
Babs's Avatar
Hmmm definitely in for results comparing the GT600r and the HTA86. Looks like an awesome build
Old Jan 16, 2010 | 09:59 AM
  #33
Wickedwhite8's Avatar
It's always awesome to hear about your builds. When I get rich I will be bringing my car to you for a full build. Thanks for sharing your build with us
Old Jan 16, 2010 | 11:15 AM
  #34
David Buschur's Avatar
There will not be a comparison of the GT600r and HTA86 in this thread.
Old Jan 17, 2010 | 04:25 PM
  #35
scheides's Avatar
EvoM Moderator
Suck that the stock motor had to be pulled, that is extremely disheartening, and even more silly if it was really caused by a faulty relay. Tephra's knockCEL probably would have REALLY helped save this motor
On the up side, awesome-*** build! Can't wait to see the results!
Old Jan 17, 2010 | 05:32 PM
  #36
TastyWasabi's Avatar
This is going to be a beast.
Old Jan 18, 2010 | 09:52 AM
  #37
mlomker's Avatar
I dunno. Shane has always said that knock detection on the X is poor.
Old Jan 18, 2010 | 12:40 PM
  #38
Update.
The engine is fully assembled and back in the car. We are waiting on a few parts still for the trans to come in and then the new Exedy Triple Disc clutch can go in along with the trans. Then with the engine in it's proper location we can start building the turbo kit.
Today I took apart the factory shortblock. It's pretty amazing how good it all looked. All of the main and rod bearings were exceptional, pistons 1, 2 and 3 were also in excellent condition, rings were free and no signs of detonation on the tops or skirt. Each piston did have some damage to the top from lose parts from #4 piston making their way into those cylinders. #4 piston was destroyed on the top, right down to the top ring. #2 ring and the oil ring were also still free and in decent shape. Bearings on #4 were also in excellent shape.
The block is being machined for a new build now and I am anxious to see how the cylinder bores measure before the new work is started.
Old Jan 19, 2010 | 08:09 AM
  #39
abazaba410's Avatar
goofy question but did you guys do a base line before and after you ported the Manifolds and TB? I just trying to figure out if any gains are noticed. 400 is right about where I want to be so Im just curious.
Old Jan 19, 2010 | 08:42 AM
  #40
Jrod@Buschur's Avatar
For those interested in updating their relay the updated version is now available in our online store in the Evo X fuel system section.
Take care.
Old Jan 19, 2010 | 09:18 AM
  #41
Golden's Avatar
That is awesome!
Old Jan 19, 2010 | 02:54 PM
  #42
Our bad *** Exedy Triple CM/HD showed up today! The car will now be buttoned up tomorrow and then the turbo kit work will start. Here's a picture of what's needed to hold BIG power!
Exedy Triple cerametalic/heavy duty:
Old Jan 24, 2010 | 02:38 AM
  #43
Another update. The engine/trans/clutch are all back in the car now.
Monday morning, if the laser cut SS header flange is done, we will be starting on the 35r kit for the car. I have it layed out in my head already and should go very smoothly. I'd expect that our turbo kit should be released and ready for sale by the end of the week.
Old Jan 24, 2010 | 06:27 PM
  #44
motox502's Avatar
Cant wait to see it finished!
Old Jan 25, 2010 | 10:32 AM
  #45
Evo a Mula's Avatar
Take care.
I was looking for this..but I could not find it on the website.....nice to see you guys really putting in the time on the evo x unlike a lot out their that seem not to care about the platform
Quick Reply: Buschur Racing's major EVOX build
