EVO X Tearing Up the Dubai Race Tracks
This was the championship round where he was up against some serious competition as you can see in the video. With everything from a JUN stroker motor, Agency Power control arms, and Moton coilovers, this EVO X was built for 1 purpose only… to eat Porsche cup cars!
Mods:
- - Custom Welded cage
- - ATL 100 Lt fuel Tank
- - Seibon, Rexpeed, APR Carbon body with AMS carbon roof & ralliart scoop
- - JUN front Undertray splitter
- - 2.3 Lt Jun Stroke Kit
- - DARTON Wet sleeves
- - Cosworth Head Studs
- - Cosworth Big end and Main bearings
- - kelford Stage 2 cams
- - Supertech Valves
- - Blitz carbon Intake
- - HKS Type 2 Intercooler
- - Blitz Intake manifold
- - JUN Throttle Body
- - OKADA Coils
- - HKS BOV
- - HKS Plugs
- - Bosh Motorsport with swirl tank fuel pump
- - Cosworth Fuel Rail
- - BOSCH Racing FPR
- - Deatschwerks 800cc Injectors
- - ATP Divorce downpipe
- - TIAL Wastegate
- - FP Red Turbo
- - Ralliart head gasket
- - Agency Power Crank pulley
- - AMS Engine & tranny mounts
- - Custom 3” exhaust
- - Mitshimoto Radiator
- - Accusump
- - HKS Additional oil cooler
- - JUN Baffle Sump
- - Exedy Clutch & Flywheel
- - Carbonetics & Ralliart diff
- - Hotchkis sway bars
- - Short shifter
- - AP Racing racing brake system
- - Moton 3 ways
- - Ralliart solid bushing
- - AMS Diff Mount
- - Agency Power Control Arms
- - Megan Racing Toe Links
- - Bespoke racing LMP Wiring Loom by DC Electronics
- - Full Motec including Diff controler
- - Run Slicks size 240 Dunlop
- - Weight 1300 KG Dry
- - 350 WHP (1.4 bar boost ) Limited to regulation to 4 kg/WHP can pull 450+ WHP with this setup at 1.8 and tune.
Looking good, but with a 2.3 stroked motor, you would have done much better with a bigger turbo. FP Reds are better on 2.0 stock motors. Go full Garrett GT35R. You'll blow past those Porsches like no ones business..
Only thing I noticed that lots of ground was made up under braking but they seemed to not apply power until really late out of the apex of the turns. Maybe they are pushing hard into the corners and then had to lift to recover to avoid wiping out like at 4:10? If you could hear the tire noises a bit better instead of the engine revving it would shed some light on when traction was at the limits.
