AEM Water / Methanol Injection Kit
yeah failsafe
the Aquamist kits have:
a) low tank level warning
b) under AND over flow failsafes
Combine that with an ECU that can switch maps and you have a pretty bulletproof solution...
I am sure other kits have the same setup, but Aquamist have been in this game for a long time and IMHO have the best kit...
Basically, water/meth will not affect your car in a negative way. The only way you can harm something is if the water/meth kit fails, or stops working, and you don't have failsafes installed. Then the damage is major....you could blow the engine.
But if the water/meth kit never stops working, you shouldn't have any issues. It's just like running higher octane gas. I ran a kit for 2 years on my VIII with no problems. I may get one for my X at some point in the future.
i ran water/meth injection on my car. they've been using this stuff for a LONG LONG time. used to use it in drag cars, etc.
in case you don't understand, which im assuming you dont, water meth injection is sprayed as close to throttle body as possible in the LICP. it cools down the charged intake air temp. thus you tune for greater timing and higher levels of boost.
in your case, i would get rid of the cat and run water/meth.
also, on a side note, i'm currently selling my AEM 1 gal meth kit if you're interested. PM me.
i decided to run a different setup for my car.
http://www.socalevo.net/index.php?op...&topic=96760.0
I'm planning on getting a kit once I buy my X after the new year. Not meth but the smurf juice(windshield fluid). Check out pics of someone doing a build after using WI. The internals are much cleaner.
=Jason-
=Jason-
NS@AEM
May 6, 2010 04:20 PM
vroomevo
18
Mar 31, 2009 08:13 PM
THmotorsports
57
Jun 4, 2008 03:22 PM
