bird crap on paint!?
#46
i think birds just like to poop on bright cars. i need to post more pics of the bird poop massacre that happened on the hubs red evo. he parked right under those electric posts wire (whatever you call it) and all the birds sat and splattered all over his car. when he got home he was pissed. so funny.
#47
i got bird crap all over my spoiler and seems the sun caked it on there.. well i cant seem to get it off and it seems that it has ate my paint.. whats the best way to try to get the bird crap off?? does bird crap even eat the paint?? i mean it was only parked for 5-6 hours?
#48
Mits paint jobs suck! Thats all you have to say. I have a old jeep and i barely wash it and it collects bird crap all the time. But when i was it you can never tell where the bird crapped at. On the other hand, my X will have bird crap on it for 2 hours and it will stain the paint. I put a nice coat of cleaner wax on then a different kind of wax on with (both with a buffer) and it makes the crap stain alot less noticeable until the wax wears off.
#49
#50
I had the same problem. Usually I try to Zaino a new car as soon as I get it, but I was forced to wait a few weeks with mine and sure enough a bird crapped on the spoiler before I could protect it. In the past, I have never had a problem with bird crap. At most, I would have to break out the clay bar. This time, I had to go as far as to get the buffer with the strongest polish and the strongest pad. It took about 15 minutes of buffing to get it out. I've never seen anything like it. I'm not sure if I can blame the Mitsubishi paint or the lack of Zaino for making the difference.
#51
Interestingly enough, Zaino sealants aren't every good at protecting against bird crap. It's the most common complaint with the product, other than noobs being frightened by the process. Zaino does provide a very slick surface that allows the crap to be removed with greater ease, but a commonly available OTC Carnauba wax offers better protection against bird droppings.
My only problem with wax is the frequency that it needs to be re-applied, especially in the Nevada heat.
#52
What would you have recommended? I started with quick detail spray, nothing. Then clay bar. Then scratch remover. Then Menzerna super intensive by hand. Then with an orange pad on a low setting. Then finally with a purple wool pad on a high setting.
#53
I have had very good luck with it blocking contaminents as well as rock chips. The biggest problem I've had with it is with water spots which I know a lot of people complain about. It seems like it allows water to get through and then not escape.
#54
http://www.autogeek.net/pc7424-menze...ramic-kit.html
#55
I was asking about the pads, because wool and SIP is a very aggressive combo, especially for our relatively soft paint.
As I'm sure you know, Menzerna polishes need to be broken down. This requires heat and friction. The PC, although a very useful tool, cannot break down the polish easily with a bigger pad. A smaller pad, like a 4", works a lot better with Menzerna and a PC. In essence, the tool isn't working the polish well due to the enlarged surface area of the pad. Menzerna polishes work great with a rotary and a Flex DA with virtually any pad. The PC needs a more specialized approach.
Have you heard of the KBM (Kevin Brown Method)? It involves a PC and Meguiars 105/205 polishes with non-diminishing abrasives. Unlike Menzerna polishes. 105/205 don't need to be broken down. The longer they're worked, the more pressure, the more they cut. In the last couple of years, these products almost revolutionized PC use. It's a very simple and effective process. Run a quick search on Autopia.
Getting back to the bird crap, I imagine it etched itself into the paint, given the need for polish. As a first step, at the risk of stating the obvious, I'd suggest using a LSP that offers better protection. This way, you'll have time to take care of the mess before it damages the finish. If you do need to polish, I'd start with KBM and a white pad with M205. M205 is a fine polish typically use for finishing, swirl removal, and other light tasks. Used per KBM, I bet it would take out the etching. If not, white pad with M105 per KBM. I think you'd be surprised by the effectiveness of the process. To give an idea, polishing with KBM takes 1/4-1/2 the time of a traditional polish with less risk of damage to the paint. Like I said, run a quick search on Autopia or Truthindetailing for examples of the process. Youtube may have some videos, as well.
#56
One thing I have noticed is black cars are particularly vulnerable. Why U ask? Because they can see their reflection in the black surface (more so than other colors) and think there is another similar bird in their territory and so attack the car...dropping poop is a common method used by birds to say..Stay the hell away.
Yes I know, this is more than U wanted to know about bird sh***t.
Later, Ken
Later, Ken
#59
I've had 2 professional shops (dealer and a detailer) try to remove a spot left on my RR X. I tried various compounds myself. Nothing. The only change was that the dealer added a nick to the paint that wasn't affected, then denied me when I asked about paint warranty =/
The worst part: I got the bird crap on my car WHILE IT WAS IN MY GARAGE! Dead of winter, a bird gets into my basement and craps on my car. FML
