Upgraded injectors necessary with water-meth?
Searched, but to no avail. Does one need upgraded injectors with water-meth injection or will the stock ones do? Thanks in advance!
Stock injectors can handle ANYTHING the stock turbo can handle. I run 50/50 mix (by weight) and am fine.
True if you actually run meth, but really depends on what mixture you run. Methanol IS combustible and will provide additional fueling. Pure water obviously is different.
+1 on getting a tune after install.
