Is it ok to replace oem light/bulbs with higher wattage?
Hey guys, I just want to ask your opinion re: replacing oem wattage bulbs to a higher wattage bulbs, I'm planning of putting H11 bulbs with 12 volts/100 watts , 3000 k temp? Any opinion/advice will help! Thanx! I just want to make sure I'm not gonna mess up with my harness. Thanx. I appreciate it!
I don't know what the wattage on the original bulbs is, but if 100W is in fact almost double, then you should not do this. You can probably get away with a modest increase in wattage, but doubling it will undoubtedly cause you issues. Issues either immediately apparent (wiring melts, headlight housing melts), or slow-acting (headlight temperature increase heats the plastic, causing your headlight covers to get hazy and opaque).
TxFAkuma
Sep 30, 2015 08:55 AM
