Test pipe with stock exhaust system pros and cons?
I am planning to get the ultimate racing testpipe for my stock exhaust and wonder if theres any pro and cons to that. Reason for me doing this is that my exhaust will look exactly stock while running a test pipe.
Guys please let me know what I should do! ....will this combo work at all?
thx, drew
thx, drew
It will work, as far as gains I am sure you might see a little but not as much unless you upgrade your full exhaust system. Also keep in mind, that the minute your downpipe and or High flow cat or test pipe is changed, you will need to get a tune. Any real tuner will tell you this. As far as cat back goes you can swap out without a tune, but the main components such as test pipe you will need a tune. Hope this helps you out.
IMO I dont see the point in changing out to a test pipe while running the stock exhaust. Save up your money and change out the entire exhaust. If you want a stock look, you can always go with the buschur set up since their well not "theirs" but they use the magnaflow muffler set up which will look fairly stock. I am not a buschur fan, but it will suit your needs.
test pipe will yield a bit for you. the cat was my major restriction when being tuned, i opted for cat-back at first, and quickly realized it wasnt worth it without a testpipe. Installing testpipe day after my tune, caused some crazy overboost, as no more restriction from that tiny lil cat.
you only need a tune if you flash'd first, then add the test pipe
as a side note, gotta love how EvoM forbids street racing threads (state-level misdemeanor at best) yet we can freely discuss running without catalytic converters on street cars which is a federal felony!
![US Flag](https://www.evolutionm.net/forums/images/smilies/smillie_flag.gif)
it's bad enough our cars struggle to achieve 20mpg on a good day... but seriously, do you really need that extra 5whp? get a small battery and lose 20 pounds and you'll go just as fast
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
